I was using a Deore M615 with an 11-40 which is about the limit for that mech, but I’m fancying a bigger range cassette so I ordered a “Derailleur hanger extension” (basically a poor mans version of the Wolf Tooth Road Link) from ebay for ~£2 (actually ordered two with a view to maybe extending my CX bikes gearing).
It arrived the other day, admittedly the finish is a bit rough but it should do the job, looks like it will lower the mech about 15mm-ish…
But are SunRace (or similar) doing a cheapish 11-44t or 11-46t 10speed cassette yet?
I’ve not seen many, failing that, is there an extender?
I reckon the cost/benefit break point probably comes once you are throwing more than ~£50-60 at a 10spd ‘bodge’, after that you will probably start mulling the ~£250ish for proper 1×11…
