Viewing 40 posts - 1 through 40 (of 61 total)
  • Best piece of biking advice…
  • chrisgibson
    I have been looking at ‘how too’ videos a lot lately and there is always the same pieces of advice floating about. Thinking about my own riding and what piece of advice I have been given which has made the biggest difference in my riding.
    I’ve come up with ‘don’t squeeze the brakes’ as the best piece of advice I have been given. Sounds simple but is really hard to follow in practice when you feel like the bike is running away from you on a quick descent.
    Which made me think, what is the best piece of advice you’ve been given?
    The more odd sounding the better!
    Rorschach
    Have you thought of golf?
    jam-bo
    look along not down. .
    ton
    do it for enjoyment
    richardthird
    Laser cock!
    swamptin
    “Arse back, elbows and knees loose.” which was given to me by a good mate before he pointed me down a skree line in a quarry. Close second is “Look 5 foot or more in front of your wheel.”
    qwerty
    Don’t ride to the top of a hill, ride over it.
    It never gets easier, you just go faster.
    Chin up, look along,
    Steer with your hips.
    In order to make a small fortune in the bike business, you need to start with a large fortune.
    It’s not about the bike.
    bright
    Have fun!
    qwerty
    It’s all bollocks.
    honourablegeorge
    Look where you’re going not at the ground
    “I’m going really fast” isn’t a reason to pull the brakes
    chrisgibson
    laser cock!
    Richardthird – any elaboration on that?
    chrisgibson
    qwerty –
    – one of my favourite quotes!
    The look ahead advice is a good one, very useful too!
    Milkie
    Depends what the person does naturally and what level they are at.
    Look ahead, not what you are going over. If you look at a tree, you will probably hit the tree.
    Look around the corner, not straight ahead, turn that head, i wanna see your chin on your shoulder in those tight berms.
    Lean on the inside handlebar.
    Try and relax.
    There are loads more, but I find any more than 2-3 things and it won’t stick with them.
    gatsby
    Look for the hinges on gates. That way you can always ride up to the end that opens. Sounds obvious, but I see so many people ride up to the hinge end and scrabble about for the latch. Once you out that they can usually see the hinges from a distance they find gates a lot less frustrating!
    Junkyard
    It means point your groin where you want the bike to go in say a tight switch back..ie turn your hips
    richmtb
    Look at where you want to go not at what you want to avoid.
    Milkie
    Nah it doesn’t!
    It’s all about riding nude with a laser strapped to your cock. When riding past Ramblers you must do fake laser noises. Pew Pew!!!
    If you can’t grasp turning your hips in tight switchbacks (Alpine Switchback), put your outside foot forward which will help rotate your hips into the corner.
    chrisgibson
    I think making laser noises as you pass people should be standard beginner advice from now on. Nothing else.
    Pew pew!
    TiRed
    commuting IS training
    breath out and relax your grip
    bikes go where you look not where you steer
    weight the outside pedal
    coasting is a pernicious habit
    use both brakes
    speed comes with technique not testosterone
    CheesybeanZ
    I’ve had “stop fighting the bike , its better than you ” said in an encouraging way by a much much better rider than myself , he was right . Between the grip of death on the bars , heavy handed braking and not relaxing I was choking the bike .
    RobHilton
    Ignore any advice from someone telling you how to ride something they can’t ride.
    If it seems like a bad idea it probly is.
    If you believe you can do it, you probly can; if you believe you can’t then you’re defnly right.
    Braking doesn’t slow you down.
    swavis
    “drop your heels” when riding down steep stuff always seems to stick in my head
    dazh
    Best bit of advice I’ve received: Drop your heels on descents.
    Advice I often give to others: Go faster than you think you should.
    Spin
    Go loose.
    Malvern Rider
    Always remember that you first loved riding. Long before the upgrading/’perfect bike’ bug bit your eyes and pocket and nibbled away at your ride time.
    igm
    Pedal damn it
    Stevet1
    Don’t listen to the (doubting) voices in your head – prove them wrong.
    iainc
    ‘straighten legs a bit, heels down, flatten back with aim of having it close to parallel to top tube, elbows out and bent’ – the lasting words from a coaching session which make huge sense if only I could remember to do it 😳
    smatkins1
    The fastest way to become a faster rider is to ride with faster riders.
    If you do anything enough times you’ll become good at it.
    RobHilton
    For ducking under a low-hanging branch?
    theotherjonv
    Yes, but……
    If you do it wrong over and over, you’ll just get very good at doing it wrong.
    Learn to do it right, even if it it feels wrong. That’s you unlearning the ingrained bad habit.
    Keep practising doing it right until it feels right.
    Then practise it until you get very good at doing it right.
    I see too many people (in all sorts of semi-technical sports) get told the right way to do something, try it a few times, find variable results because it isn’t well enough practised and ingrained yet, and then say **** it and go back to doing it wrong because it feels right.
    bigjim
    ignore anything you read on stw
    matt_outandabout
    He who has most fun, wins.
    wwaswas
    buy these forks from the classifieds – they’ll change you into a riding god even if you never actually touch the bike again.
    http://singletrackworld.com/forum/topic/marzocchi-44-rc3ti-140mm-of-buttery-smooth-plushness
    Marin
    Sod it just ride it and see what happens.
    partickbateman
    Heels down, eyes up!
    thisisnotaspoon
    Don’t train[i]try and get fit[/i] on the bit’s you enjoy.
    Riding round the same trail every day will get you fit, but you’ll be bored of it by the end of week 2, after which you’ll never want to ride it again. Riding on the road* will get you just as fit, and you’ll actualy want to go out and ride.
    *or going for a run, hitting the gym, commuting, doing 100 sit ups.
    martinhutch
    Relax, hard.
    I think that was about biking, might have been at my last doc’s appt. 🙂
    edward2000
    Relax.
    Then relax some more.
    Then shut up
    Tom_W1987
    Look down the trail at these in order, Entry – Section/Apex – Exit
The topic ‘Best piece of biking advice…’ is closed to new replies.
