Need a new wheel building stand but budget only around £100. Do not want to build my own. Needs to fit 20mm front and 142/150mm rear axles.
Any recommendations?
make one from the wheelpro book or use an old set of forks with zip ties
+1 for the Wheelpro one.
I know you said you didn't want to make one but I agree with those above, the wheelpro one is extremely easy to make - needs some bolts, some mdf, some acrylic sheet and a couple of bits of metal bar for the jaws. It's about a quarter of the cost of any other decent stand even after you have bought the book. I made mine mostly out of bits I had in the shed so it was even cheaper.
No time or ability or facilities to build my own, hence the "do not want to build my own" comment. So looking for a stand that will take a 150mm rear and 20mm front etc.
You must log in to post.
