BB7 Outers - full l...
[Closed] BB7 Outers - full length or not?
[#1368602]
I've had BB7s on the Sutra since I got it and am now building up something else, but the new frame has cable stops. So, I have a bit of a dilemma; drill them out/cut them/fit crappy adapters to run full length again, or use the cable stops as intended. I'd fit those nice XTR-style end caps of course....
Posted : 28/02/2010 2:52 pm
 IA
Use the stops, then if you decide you don't like it later, change to full length. Obvious innit.
Posted : 28/02/2010 3:12 pm
Gore brake cables? Full inner sleeve covers whole cable but fits through eyelets. Nice outers too.
Posted : 28/02/2010 3:25 pm
sp41, teflon coated inners. Problem solved
Posted : 28/02/2010 3:30 pm
Or just zip tie a full length outer to the frame. Not pretty but functional.
Posted : 28/02/2010 3:37 pm
Ah - you've not met me then....
Posted : 28/02/2010 3:57 pm
pretty much no maintenance with full outers
Posted : 28/02/2010 5:44 pm
Avid FMJ's work very well with BB7's.
Posted : 28/02/2010 5:46 pm
When I used Avid mechanicals, I used Gore Tex cables - did the job nicely. Did use full length outers once when I ran them on a FS bike, and that was OK, but a pain in the arse to keep the cable lubed.
Posted : 28/02/2010 6:20 pm
I never lube any cables. Teflon inners and SP41 outers don't need lubing.
Posted : 28/02/2010 6:30 pm
[i]Or just zip tie a full length outer to the frame[/i] 😯
Oh, the humanity...
Posted : 28/02/2010 7:08 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=1010 ]cable guides[/url]
Posted : 28/02/2010 7:13 pm
