Bathroom laminate f...
[Closed] Bathroom laminate flooring with under floor heating (electric)
[#3747091]
I have a customer who's bathroom I'm refitting shortly. They have now changed their minds from a tiled floor to laminate. They wish to keep the under floor heating ( which works well with tiles ) with the laminate. Now my question to the collective is this, has anyone fitted or had fitted UFH with laminate flooring in their bathroom and does it work ? Any views welcome. Ta
Posted : 06/03/2012 8:56 pm
It's quit possible it won't work but the only real way to know is to do the calculations. Laminate flooring (and the foam layer you often have underneath it) will have a lot higher thermal resistance than tile. This means that the electric heating would need a higher temp to get the heat through for the same end room temp. This may not be a problem but it may also be that it is too high and there is a thermal cutout.
The real answer is that I don't know but I would be concerned enough to do a detailed check before investing in the laminate. As a minimum I would look at the website of the underfloor heating as sometimes there is detailed enough info. there to work it out
Edit: just checked and I don't have our installation guide any more so I can't even make an estimate - sorry
Posted : 06/03/2012 9:56 pm
not sure if I'd want electric underfloor heating in my bathroom 😯
Posted : 06/03/2012 10:31 pm
I fitted it to a tiled floor .
Bloomin lovely it is too. Used a mat type as the floor was a regular shape .
Dont know about laminate flooring , think LB is bang on though . Too much insulation and a poor thermal path . Also kinda pointless as laminates are nowhere near as cold as tiles .
Posted : 06/03/2012 10:35 pm
Thanks for the replies. The UFH supplier that I normally use ( Warm up) do a product specifically for use with laminate, but as has been said here I can't really see the point. thanks again, confirmed what I thought 🙂
Posted : 06/03/2012 11:13 pm
