“do i need anything else bar the bash guard
if you’re simply replacing your big ring with the bash it is unlikely you’ll need anything else”
ime not true, some bash rings are a fair bit fatter than a chainring
eg truvativ, shimano hone (and slx?), fsa polycarbonate
truvativ and shimano longer chainring bolts aren’t cheap (£15-20ish), The FSA polycarbonate (clear) bash’s come with longer bolts in the packet. They will also run with the torx chainring bolts from shimano cranksets
Not all bash rings are ‘fat’ though, there are many (mostly metal?) bashes that are quite narrow, so normal bolts should suffice
An FSA polycarb for eg, mine has took many a knock with only minor chipping
A Shimano 32t Hone is fairly thin/light (plastic) and after a few too many knocks (and overtightened bolts) will split. Though at £10 not expensive to replace
As far as I know a 36t Shimano SLX bash is fair bit chunkier
