Bash for 2x10?
[Closed] Bash for 2x10?
[#3639646]
I'm looking to fit a bash (but not a chainguide) to an X7 2x10 chainset, but when I last checked about a year ago it wasn't possible to fit something like a E13 Turbocharger as the profiling on the outside of the spider means it wouldn't fit.
Has anyone produced a bash that gets around this issue yet?
Posted : 03/02/2012 1:33 pm
What about the new hope one?
Posted : 03/02/2012 6:12 pm
Does that work with 2x10?
Posted : 03/02/2012 6:49 pm
Aye, just put one on my slx cranks
Posted : 03/02/2012 8:15 pm
SRAM double chainsets won't normally accept anything in the 'big-ring' position, iirc. I seem to remember SRAM have talked about releasing a different spider, but you could try a simpler taco-type system (MRP XCG, for example).
Posted : 03/02/2012 9:11 pm
So it's just an issue with SRAM?
Yeah, I had looked at those before, but I think previously MRP only did skids for singles or triples. I see that they recently designed one specifically for doubles - the XCG 40 - but it doesn't appear to be out in the UK yet. At least I can't find it online anywhere...
Posted : 03/02/2012 9:58 pm
I'd imagine it's the same for the new Shimano XT doubles too, from looking at the spider.
Posted : 03/02/2012 10:08 pm
What about one of these?
http://www.chainreactioncycles.com/Models.aspx?ModelID=31952
I would imagine that with a bit of filing you could probably make most bashrings fit though.
Posted : 03/02/2012 10:20 pm
Go Hope or go home! under £30 you cant loose.
Posted : 03/02/2012 10:22 pm
That does look very nice, but if I can't get an E13 Turbo to fit then surely that wouldn't fit either, unless there's something I'm missing?
Posted : 04/02/2012 12:20 am
The sram 2x10 cranks are 120mm pcd instead of the common 104mm of shimano.
Sram do make a bash guard to fit for Specialized, but don't seem to offer it aftermarket.
The MRP 2X/Truvativ X guide would be another option, I think they're the same & made for sram 2x10.
Or the new E13 TRS would be my choice, when they're available.
Posted : 04/02/2012 6:11 am
 bol
It's an extreme solution, but you could buy one of the new 2x10+bash spiders that SRAM have just released. I think they're only available as x9/x0, but would probably fit. They have a different pcd. I've just ordered a 38/24/bash, but I don't think they'll actually be available until March.
Posted : 04/02/2012 9:39 am
