recently i fitted 2 new radiators , 4 new lockshields/TRVs and refilled the system with inhibitor.
I then balanced the radiators with a dual sensor thermometer – – as i got pissed off with the laser thermometer method i used last time i did this.
I set them all up to have 12degrees C drop between inlet and outlet when TRV is fully open. which equates to between 1/4 to a full turn the further you get from the radiator. The inlet temp at the first rad tail is 49deg C
My issue is the radiator in my bedroom – which is one of the originals (3 years old delonghi) with one of the original danfoss TRV and lockshields Whistles like a banshee when starting from cold in the morning(at 4am convienantly….:() unless i open the lockshield up a turn or two…. its only that radiator. No air coming out of any rads when i tried rebleeding them , i dont seem to have a leak in as much that the pressure isnt dropping at all and i did a 3 bar pressure test for a good while before i filled with inhibitor and the rads all get uniformly hot.
Its a 3 year old grant boiler , with radiators ranging between 3years and 1 week, its always had fernox in it (the antifreeze one) and it has a magnaclean on it and theres a dump radiator in the system
Now i realise the obvious fix is obvious – leave the lockshield open But i want to know why its doing this …its slightly irritating in the morning…..makes me grumpy for the rest of the day.
cheers
