Avid 185 rotor with...
[Closed] Avid 185 rotor with Shimano caliper/adaptor - it can be done....(probably)
 DrP
[#3759051]
So...will I die or will all be OK?!
By using a post to post 180mm adaptor, plus a couple of washers, the intensive 'up and down the street test' would suggest that one shall survive...
TBH, I can't see it being any different to the bunch of domed washers that come with Avid calipers....can it...?!
DrP
Posted : 09/03/2012 9:38 pm
Did the exact same with mine earlier after realising the avid adaptor won't accommodate a shimano caliper. Fingers crossed!
Posted : 09/03/2012 9:47 pm
You'll live...probably.....
Posted : 09/03/2012 10:43 pm
 cp
And its no different to the spacer being slightly bigger, great stuff. 🙂
Posted : 09/03/2012 11:51 pm
Nowt wrong with that.
Posted : 10/03/2012 12:29 am
you might have room there to get a set of concave/convex washers to allow better alignment (as avid brakes)
Posted : 10/03/2012 12:30 am
As long as there's enough bolt thread screwed in? There should be.
Posted : 10/03/2012 1:43 am
Mine's been like that for 4 years. Not dead, yet.
Posted : 10/03/2012 8:45 am
