- This topic has 51 replies, 30 voices, and was last updated 13 years ago by toys19.
anyone tried those kevlar brake pads from superstar?
shaggmiesterFree Member
how good are they for alpine descents and also anyone tried the ceramic soft compound pads from discobrakes? cheers.
yesiamtomFree Memberi dont know how good they are for long alpine descents but me and my brother both used them in wales with no problems.
They squeal a lot in the wet and the braking power seems a bit poo. In the dry though i love them.
thomthumbFree Membergreat in the alps got through a pair each end in a week. which is about normal. really powerful though.
not tried them in the wet.
MrCrushriderFree Membergood in the dry – last 2 mins in the wet.
do a search there was a long thread a few weeks back….stick with sintered for the wet rides
TandemJeremyFree MemberHow about searching on here – this comes up evey now and then.
a weeks use satisfactory? Get over – a years use is reasonable.
willsimmonsFree MemberRode them in the Alps for a week earlier this summer. They were fine. Not a fan of most Superstar stuff but would recommend these. Lots of bite, noticeably more than the previous organic pads I had fitted.
hungrymonkeyFree Memberthey'll be grand. having just used some disco pads, i'd use superstar over them. not in terms of performance (never noticed much difference tbh), but simply because the superstar package is SO much easier to get into.
wartonFree MemberI htink they're good. I don't ride in the alps, I've had them in for about 200 miles, including 5 hours of 10 @ kirroughtree, they're half worn.
TandemJeremyFree MemberNo I don't Al – however I simply don't believe that the wear rates some people seem to get from brakes is reasonable. All sorts of excuses are given for this absurdly high wear rate from alpine descents to the local grit in the peaks. However I don't believe that the alps in the dry causes hundreds of times more wear than other riding.
Its very clear not everyone gets these absurdly high wear rates. I never have despite riding in places and conditions that some folk get this absurdly high wear rates. I have done some alpine riding.
I get thousands and thousands of miles out of hope original sintered. Any pads I had that wore out in a couple of hundred miles would be returned as not fit for purpose.
svFull MemberMy SSC Kevlar pads glazed over several times now back to the sintered variety without problem.
nickjbFree MemberI agree with TJ (this time) as my pads seem to hold up pretty well and I'd be unimpressed if they lasted a week in the UK. That said I can understand the Alps comment as I can easily do more braking in a week than I would do in a year in the UK. They are big and steep and I'm a mincer
M1llh0useFree Membernot managed to wear out a set of SS pads yet. just manage to keep contaminating them 🙁 they really don't like getting cleaning fluids on them (gold sintered)
Although I swapped out a set of kevlar (red) pads half way round cwmcarn and went back to sintered (gold) as the kevlar weren't working at all for me….
thomthumbFree MemberI get thousands and thousands of miles
not relevant though – we were descending some where in the region of 2-3k vertical each day. 15000m of descent sounds ok to me.
thats about 3 months of my normal riding.
willsimmonsFree MemberOne man's Alpine riding is a lot different to someone elses, so the comments about unacceptable wear rate in that time are meaningless. For the record, I did 7 days riding amounting to ~ 25 hours on the bike and the set I had still had plenty of life left in them when I got back.
FWIW 'The Alps' are quite varied. A lot of difference between some of the 1 hour slow, technical and tight trails that I tend to ride over there and 25 minute all out blasts on a fast track.
For the price they are worth it, even IF they did wear out in a week. In my experiece though they won't.
PeterPoddyFree MemberTJ, really, a weeks riding in the Alps on one set of pads is quite reasonable. You simply don't brake as long or as hard in the UK.
From memory, you use Hope brakes yes? The Mini Monos I had were brilliant on pads. They lasted me 18 months or more, but they weren't as powerful as my current Maguras, which I usually get around 6-8 months from a set of cheap pads, or 9-10 from Magura pads.
But with reference to the grit thing, if I then go to Swinley Forest on a wet day, I'll ruin a set of the very same pads with ease in one ride of under 20 miles, even if they're new. Swinley eats pads just as bad as the Peaks do it seems.
Then taking the same brakes with the same pads to the Alps, I got through a partly (Say 1/4 worn) set of pads in 3-4 days, becasue I'm braking so much
Please try telling me that's nothing to do with the conditions! Just becasue you've found one thing, doesn't make it right for everyone else old bean! 🙂Yes, sintered pads will last longer, even at Swinley, but Maguras are organic only which suits me fine. I'm quite happy with the wear rate I get for the stupid amount of power I'm still getting from 2 sets of brakes that are 4 and 3 years old respecively. 🙂
radoggairFree MemberAlthough never ridden in the alps i can see how continous hauling down of your 40+lb downhill 'machine' for nearly a week none stop could make you go through a set of pads. Bit like if you take your car on trackdays then expect your set of tyres which usually last 20000 miles to last 2000, its common sense really.
I'm trying out these f1 components brake pads which i found on fleabay for a fiver just now. After 1 ride there starting to bite at last and they dont squeal like clarks pads. I simply refuse to spend £15+ on a set of avid padsshaggmiesterFree Memberhungry monkey – Member
"they'll be grand. having just used some disco pads, i'd use superstar over them. not in terms of performance (never noticed much difference tbh), but simply because the superstar package is SO much easier to get into."
😆 yeh i know exactly what you mean, i ended up leaving some of the packaging on my sintered pair all the plastic gets stuck around the metal clip! anyway, not too bothered about the wear rate, a week downhilling in the alps is pretty reasonable i think for a kevlar pair!, think i'll order some, cheers guys.
scruffFree MemberIn one wet Verbier descent (Nuthouse) I got through the pad including backing plate and 1/4 of the caliper piston. 😳
TandemJeremyFree MemberPP – I agree the conditions make a difference but not hundredfold – however it ain't that simple – some folk still do not get the wear in places some people do. Its a complex multifactorial thing but I still don't believe a couple of hundred miles no matter how hard the brakes are used in dry conditions is satisfactory.
do I brake less in a couple of years riding than you do in a week in the alps? and thats wet as well as dry riding.
scruffFree Memberdo I brake less in a couple of years riding than you do in a week in the alps?
Yes.
stumpy01Full MemberI seem to remember Mark at Ciclo Montana mentioning that he gets between 3 & 4 weeks out of a set of pads out in the Sierra Nevada mountains & he knows the trails so well that he hops, skips & jumps over stuff that most people would be braking/swearing/skidding down.
With regards to the original question, I have used the organic SSC pads for several years now without issue. For some reason, I thought I'd try sintered for the last lot but haven't needed to fit them yet. I haven't tried the Kevlar ones. A mate is using them though and reckons they work well.
foxyriderFree MemberDon't do Alpine descents too often 🙁 But they are working well on my XC bike doing alpine speeds 😉
R979Free MemberYou lot seem to get good life out of your pads, I must have a mini-bermuda triagle around my rear elixir then. I thought I'd give the Kevlars a go in the Alps recently and ended up getting 1 (one) run per set SS of pads. I switched back to trusty A2Z pads after going though all four sets of pads I had and everything was fine again.
philfiveFree Membergood in the dry, wear fast in the wet but the 4 packs are such good value that it doesn't matter.
toys19Free MemberMY ss kevlar pads have outlasted my avid originals on my codes. SS pads are brill.
bigyinnFree MemberI havent actually ridden my SS Kevlars in the wet yet! They've been in a couple of months so far.
Liking the power.As usual kids, make sure you bed them in properly first.
Might switch over to sintered for the winter, but thats a few months away yet.
steffybhoyFree MemberSame as how long is a piece o string.
I normally get through a set of sintered pads every 12months or so(incl odd trip to fort-bill etc.BUT! during the strathpuffer last Jan, I used 3 sets of sintered(crazy).
NorthwindFull MemberCan't speak for alpine descents but I brutalised mine at fort william, all the way down the DH course with both brakes deathgripped on in terror the whole way They didn't even grumble. If they'd melted I'd still say they're decent pads considering the way they've performed the rest of the time tbh.
I just replaced that set, they'd done maybe 800 miles including that and some other uplifting plus all weather XC rides and still have a good amount of life left but I wanted fresh ones in before we go off to France. Very good indeed. They were never put through really gritty pad-eating mud though, pentlands mud doesn't seem to hurt pads as badly. I'd highly recommend them. Though having said that I'm still taking some organics with me just in case.
Now…
Just to quickly put TJ's inevitable Superstar-slating into perspective, check out this thread:
http://www.singletrackworld.com/forum/topic/superstar-components-and-10-under-the-ben
Where he declared that this, after 4 laps ck enduro, was "unfit for purpose." and "simply not acceptable"
http://farm5.static.flickr.com/4010/4608480917_13e0bdbbab_b.jpg
But then when shown what happened to new Hope sintered pads in the exact same number of laps said "Were they bedded in?" and "It's a conundrum" but not "Unfit for purpose".
http://farm5.static.flickr.com/4028/4580775617_c0b7497485.jpg
Sorry TJ… But it's true.
stevomcdFree MemberJust stuck a set in today for a day's downhilling in Pila. Performance was good, slightly softer lever feel than with sintered. Haven't looked yet to see what a day at Pila did to them (it's pretty brutal!).
For what it's worth, I generally get about 2-3 weeks out of a set of pads during the chairlift season. Hayes original sintered more like 3 weeks, Superstar sintered more like 2, but I'm not complaining. Performance has been excellent in my Hayes, a bit screechy in Iona's Formula Oros.
TandemJeremyFree MemberNorthwind – you got me a bit out of context on both those but I can't be bothered arguing. I wasn't intending to be snidey about SS on this thread altho I can see it would be taken as that.
Any pad that lasts so little time something has gone wrong and I find it amazing that people will accept this – I wouldn't no matter what the pad. I have never experienced it even in conditions that others do. Pad life should be thousands of miles
It is clearly far more than conditions tho they play a part otherwise people wouldn't be able to ride identical setups in identical conditions and get dramatically different wear rates.
toys19Free MemberAny pad that lasts so little time something has gone wrong and I find it amazing that people will accept this – I wouldn't no matter what the pad. I have never experienced it even in conditions that others do. Pad life should be thousands of miles
Both these statements are meaningless as there has been no scientific or even congruent anecdotal evidence, what there is evidence of here though is that people shouldn't always listen to TJ because he doesn't listen either, he only believes what he wants to believe..
As far as I know TJ is a nurse, well I'm a ruddy good engineer and for me so far SS pads have been as good as OE. I've had OE pads last a long time and wear out in no time on shimano and avid, and SS pads wear out in no time and last a long time on Avid brakes. When my pads of any variety wore out quickly there were factors such as alps or shite winter weather involved. When they lasted a long time it was the summer and I was doing XC. I think environmental conditions and usage could easily have 100 fold or even 1000 fold impact on pad life. Thats S>C>I>E>N>C>E fact, not some blubbering made up by a nurse.
NorthwindFull Member"Northwind – you got me a bit out of context on both those"
I did link the entire thread to give the full context 😉
philjuniorFree MemberTJ – if you go to the Alps and do a week with uplifts it's a reasonable expectation to have to change pads, even if they're new at the beginning of the week, and even if they're good. I don't often ride in the Peak, normally get months out of a set of brakes, but have got through a set of roughly half worn pads in a day's wet riding there – as did everyone else I was riding with. Nothing wrong with our pads, just that ours is sometimes a silly and pricey hobby.
If you ride in certain other conditions wear rates will be increased, but in the Alps it's just the gradients you end up riding down and the temperatures and constant braking that goes with the temperatures that make your pads wear away fast. Basically they'll be smoking away for most of every descent unless you're less than 9 stone and running Hope Moto's.
In any case, if TJ had slated SS I could understand it from some of the historical threads where some interesting opinions were aired (NOT by TJ!)
TandemJeremyFree MemberToys – I have actually much "congruent anecdotal evidence" And science from the journals and opinion from the manufacturers on this.
You think so that is science fact. Oh rly!
Hoist by your own petard boy. are you drunk?
toys19Free MemberYou think so that is science fact.
That is pretty much the size of it. My thinking is a **** sight more scientific than yours nursey. I'm sober, still at work and really peed off. Was feeling up for a fight and who should come into view….
Show us your
toys19Free MemberPS don't call me boy I have a feeling I'm a bit older than you, it's easy to tell, every time you open up your gob a huge lack of experience falls out.
The topic ‘anyone tried those kevlar brake pads from superstar?’ is closed to new replies.
