anyone run tubeless...
[Closed] anyone run tubeless without sealant?
[#3155496]
Ive got tubeless rims and TL ready tyres that are fully inflated - but no sealant at the moment! what do you reckon my chances are of getting round a ride without any flats! daft question i know, but just wondered if anyone runs tubeless regularly without the sealant?
Posted : 16/09/2011 7:33 pm
I reckon you have about the same chance as you would running tubes
Posted : 16/09/2011 7:34 pm
yeah thats what i was thinking - gonna take some tubes anyhow 🙂
Posted : 16/09/2011 7:36 pm
I ran UST rims and tyres wihtout sealant for ages. Just take a tube.
Posted : 16/09/2011 7:49 pm
I did the same until I got a thorn puncture that also holed the tube I put in...now I use sealant.
Posted : 16/09/2011 7:57 pm
Back in the day (like 10 years ago) mavic actually said UST was not to be used with sealant - I think over concerns that some sealants could corrode the tyre.
So no sealant is fine. It does seem to generally maintain the bead sealing to the rim though - cuts down on mini air burps or something similar.
Posted : 16/09/2011 8:33 pm
yeah that was a concern GL, but i run quite high pressure anyway (35psi-ish!)soim hoping that wont be an issue!
Posted : 16/09/2011 9:32 pm
Why would you [i]not[/i] want to run sealant?
Posted : 16/09/2011 9:38 pm
i just dont have any at hand! i will do eventually
Posted : 16/09/2011 9:53 pm
Tubeless Ready tyres are normally designed only for use with sealant... But it might be fine, who knows?
Posted : 16/09/2011 9:55 pm
I ran tubeless and ran without sealant and got a flat 🙁
Posted : 16/09/2011 10:44 pm
 grum
I've run mine for ages when the sealant has all dried up.
Posted : 16/09/2011 10:49 pm
 mboy
That's slightly different though, as the sealant has already done a job by this point. Only thing it isn't going to do is fix a new thorn puncture, but it's already stopped the tyre being porous.
I was a fairly early adopter of UST, around 2003 I think, and ran UST without sealant for a while as was yet to be convinced of the need for it. A couple of thorn punctures put paid to that, and when I realised just how heavy proper UST tyres were (fine for DH, less so for XC), I decided lighter tyres and sealant was on the whole the way to go...
Posted : 16/09/2011 10:58 pm
+1
Posted : 21/09/2011 2:45 pm
Similar to PMJ and mboy, I got some very early Crossmax USTs in 2001, there was only 1 UST tyre, the idea of sealant didn't really exist. I got few flats, but tyres were heavy. Had a couple of tyres develop tiny leaks and it was infuriating trying to find out where they came from. I nearly trashed the rim putting 80psi into a UST tyre which subsequently exploded, whilst looking for a leak!
Then went to an 'Eclipse' system about 2003 with non-UST tyres and sealant, loads more faff, but saved tonnes of weight. Then got Stan's rims. That was a revolution.
I'd not run a non-UST tyre without sealant and expect any longevity. But all that'll happen is you'll puncture, so take a tube, and see what happens.
Posted : 21/09/2011 2:53 pm
