Gave up with far east ones, the original magicshine ones were reasnoble, mine must be on its 5th winter and its now down to about 90min on full.
But others (even UK bought ones) have either been crap out the box or failed quickly.
I’ve now got 4x Samsung 3000mah protected 18650 cells* in a solarstorm box and a nitecore charger. So at least the cells will stay ballanced even if it takes 30s more faffage to charge.
Also got a nitefighter light on its way with a battery. Reviews suggest its panasonic cells (and its expensive enough to make tgat believable) so as long as it stays ballanced it should be good.
*yes there are higher capacity cells and cheaper cells but after a bit of digging these have a high enough current output to make the springs in the case the limiting component, they’re protected, and they were half the price of panasonic which were higher capacity and current but the extra wasn’t required.
