Anyone had a new bo...
[Closed] Anyone had a new boiler fitted recently??
[#3387550]
if so can anyone give me an idea on the sort of cost i can expect to rip out an old regualr boiler and tank and replace with a new combi boiler.
3 bed house with 7 rads if it helps.
boiler is likely to be a viessmann 26kw 100 range model.
cheers
steve
Posted : 24/11/2011 6:20 pm
Replaced a v.old conventional and tank with a Glow Worm something-something in March. Also 9 new rads, 3 bed house. Was about £3500 I think. Would have been more (about another grand from memory) if we'd had the pipework replaced too. Can look up specifics if you need me to.
Happy so far but it hasn't been *that* cold yet 😉
[edit]Just checked, it was £3580. Was the middle quote of three IIRC but liked this guy better, and this has been borne out, he's been great in the meantime with little (unrelated) jobs here and there[/edit]
Posted : 24/11/2011 6:23 pm
Is the combi going in the same position as the old boiler/hot water tank etc?
Posted : 24/11/2011 6:27 pm
 5lab
around £2500, using existing radiators. its worth noting condensing boilers don't run radiators as hot as old boilers, so if the house is struggling to get warm at the moment, you may need some bigger rads
About 2500. We had the one you're lookIng at installed last year.
You've got to factor in the cost of the yearly service if you want the 5 year guarantee to remain valid
Posted : 24/11/2011 6:30 pm
boiler will be going in the same place as the old one.
running 7 rads and the house was plenty hot enough with them and quite efficent.
ive been given a rough estimate by the bloke who will be fitting it...
new veissmann 26kw vitodens 100 boiler
flush of old rads and refill with some inhibitor etc.
looking at around 1600(slightly more if needing a vertical flue.)
does this sound reasonable?
Posted : 24/11/2011 6:32 pm
how are you finding the boiler so far then?
how much is the yearly service?
Posted : 24/11/2011 6:37 pm
I paid 950 inc flue for a vitodens 200 33kw combi this time last year, a 26 is prob about 60 cheaper so your plumber wants 700 for the job. Say it takes him 3 days, which it shouldn't....
Posted : 24/11/2011 6:38 pm
Probably not much help, but we had one done about 6 months back- London prices, never sure whether this makes it cheaper or more expensive- remove and dispose back boiler, hot water cylinder and loft tank, upgrade to 22mm copper pipe from street, power flush, install combi, and 2 new rads -£700. We supplied boiler and rads, he supplied copper. No making good.
Posted : 24/11/2011 6:39 pm
are worcester bosch boilers any good.
mate can discounts on greestar junior models.....
24i 650 quid
28i 730 quid?
Posted : 24/11/2011 7:15 pm
When we had ours done the hot water tank was out and taken by the scrappy within the first hour.
Not sure what it was worth but it could be to your benefit to remove it and flog it yourself later on.
Posted : 24/11/2011 8:19 pm
 jonk
My mate who is in the trade highly rates Main boilers. He fitted a Main combi 30 recently for me for £710 all in.
Posted : 24/11/2011 8:46 pm
We just had:
WB 24i
New flue
WB DT10RF wireless thermostat
Inline descaler fitted to incoming supply
Condensing pipework fitted
Some extra pipework replaced
Powerflush and clean of CH system
£1800. The other two quotes were £2650 and £3500! But they were from WB acredited suppliers so you'd get a longer warranty if you had them service yearly.
Posted : 24/11/2011 8:50 pm
richpenny whereabouts are you based??
Posted : 24/11/2011 9:19 pm
Worcester - make sure you get the condensate pipe lagged to prevent freezing. If you're an absentee landlord you don't want to paying for a plumber to come out at night cos the boiler's stopped working.
Am in Salisbury renton. My condensate pipe runs totally inside the house so should be fine. Just drains into the waste pipe for the washing machine.
Posted : 24/11/2011 9:46 pm
Our 1st service was £50, took him about 20 mins.
Boiler has been great.
Posted : 24/11/2011 10:38 pm
I have the WB28 i and it works fine no probs so far. 5 yr warranty on everything as well iirc
Posted : 24/11/2011 10:48 pm
Had a combi swapped out for a condensing combi earlier this year, cost £1100 with a filter and exisitn pipes/rads etc, took him about 6 hours to do.
Posted : 24/11/2011 11:01 pm
Posted : 24/11/2011 11:03 pm
if your mate can get 24ijnrs for 650 inc. i'll take 20 now and 6 a month till may..
Posted : 24/11/2011 11:44 pm
i love hearing folk talk bullocks..
accredited WB installers give no more warranty than anyone else, you can buy a 5 yr warranty for 99 at installation plus an annual service form a WB trained installer.. WB expect you to be charged circa 100 plus if done to the spec would take circa 1 hour and include at least a boiler case seal and a service certificate stating gas presures and co levels.. you aint got the paperwork, you aint got a warranty
Im WB accredited and trained a 24i nr can cost as little as 1150 as much as 2200 depending on specifict installation and take from 40 minutes.. ( i jest not) to 3 days.
besdie the cost of the boiler before you deduce the guy made 700 quid understand that he has to be in gas safe to fit it ( 170 a yr) he has to hold 4 different gas exams an electrical qualification (150 +vat each every 5 years) he has to have an exhaust gas analiser ( 450 initial cost plus 100 a yr servcing plus parts of circa 80 pa)and finaly he has to register the boiler with gas safe/ local authority.. who ll then send you a certificate.. not had it yet.... oh dear no warranty..
Posted : 24/11/2011 11:50 pm
yes ime
a couple of thousand supply at fit sounds reasonable. took the gas engineer more than 2 days to do mine and I did all the labour
Posted : 24/11/2011 11:51 pm
total shell fancy coming and fitting me a boiler then ??
Posted : 25/11/2011 12:04 am
 Bear
bloody hell my gas courses are way more than that (SE england)
As TShell said you can work for a couple of hundred per boiler but you'd go bust quickly, overheads are big these days.
Posted : 25/11/2011 12:55 am
just had a call from the plumber...
he has given me a firm quote of £2000 for the following
remove and dispose of old boiler and tank
supply and fit a veissmann 30kw combi boiler
supply and fit a siemens 7 day digital clock/programmer
flush system and refill with inhibitor.
do you think this is a fair quote.
he said it jumped up a little bit as he has to use a vertical flue ?
Posted : 25/11/2011 1:56 pm
renton .. tell him..
you want a WB 28i jnr with rf wireless programmable ( salus) and a magnaclean or similar and you keep the scrap for the 2k..
the magnaclean will do the job of the inhibitor and remove the crud forever and ever and you can see it there.. your old cylinder and pipework is worth circa 80 -340 though generally less than 150..
the materials will set him back circa 1100- 1200 max giving him a nice pocket for 3 days graft.. ( the vertical flue kit is 172.56 from memory) barter hard and succumb to him taking the scrap but dont move from that.. there are literally hundreds of very experienced installers out ther having been made redundant this year.. any of them would do a 2k swap..
you dont need a 28kw tbh honest WB are including a chip in all thier boilers now to bring the CH KW down by 50% as you just dont need your central heating hot in 20 mins when you d be happy with 40.. all you get extra is more hot water at the tap for your larger KW.. a 24 might deliver 9 litres per minute a 40kw might be 15litres per minute..
add up how manu hot water taps you have ( inc washing machines dishwashers etc) and ask how often will all or most be used at the same time.. if you have a 5 bed house with ensuites and 3 teenage daughters you ll use a lot of hot water and thus need something like 41kw if your billy no mates have 1 bathroom then 24 is too big.. couples i spec 24kw kids etc ensuite 30kw teenagers etc all the toys 40kw.
WB because its the countries biggest thier website has everything you and i could want to know they have parts from a zillion years ago.. many of thier own parts are generic to other brands but used as they are cheaper than the other brands spares
i have never in 6 yrs working for my self ever had to repair a WB i have fitted.. i wish the same were true of Alpha ( 1 boiler 3 repairs) and ravenheat ( 1 boiler 10 times in the first year.. RH came out to it twice before we could get it to work in the first place...)
Posted : 25/11/2011 2:45 pm
thanks for the reply.
i would go for a wb but the chap i know who fits wb cant fit me in until the second week of january.
i cant leave my tenants without heating or hto water until then.
ive read good reviews on the veissmann boilers too.
its going into a 3 bed house with 1 bathroom and 1 downstairs toilet with sink.
also will eventually be running a shower when the current electric one packs up.
oh he is also fitting a siemens digital time clock thing
Posted : 25/11/2011 2:53 pm
did a very similar project in june of this year
old boiler with cold water storage in attic space and primark hot water cylinder in bed room on first floor
8 radiators in total
changed to a baxi combi boiler 28kw and removed the old boiler and old tanks, new boiler in same location as old one, so now no water storage anywhere all direct feed off mains
kept the same radiators apart from kitchen one which we moved to other side of room.
total cost for all parts and labour £1300 including VAT
and the baxi combi has a 5 year parts and labour warranty
Posted : 25/11/2011 3:02 pm
did you do that yourslef or was that done by a plumber?
Posted : 25/11/2011 3:05 pm
he didt pay for the labour for that money.. the baxi has 5 yrs parts and labour if registered with building control and serviced by baxi every year..
Posted : 25/11/2011 3:14 pm
 hora
Cost me £600 I think. I bought the boiler myself from a wholesaler. I also went for a 30c due to the size of house etc etc.
I had a British Gas guy round to give me a quote and that was £2,700 with their special discount.
One thing I did kick myself over- I didnt realise (****ing idiot) that the old cylinder upstairs was a solid copper number..... the boiler/gas fella took that away and 'disposed of it'. ****!
Later on we decided we needed the radiators replacing.... that was £950 for 7 radiators supplied and fitted.
Posted : 25/11/2011 3:26 pm
we had our very old boiler, water tanks and hot water cylinder replaced with a WB 27i - £2300 for an excellent service from Transgas in Surbiton.
Posted : 25/11/2011 4:03 pm
Getting a old bolier ripped out next monday and a condensing combi bolier fitted. The house is a semi detached with nine radiators, which are all ok.
New Ferrori boiler with 5 year parts and labour guarentee, £ 600 inc vat from wholesailer and £ 550 for plumber to fit, hes having the old copper cylinder as part ofthe deal.
Posted : 25/11/2011 4:33 pm
i wouldnt touch a ferroli boiler with a barge pole.
my brother in laws is crap, does nothing but leak everywhere!!
Posted : 25/11/2011 4:42 pm
I had a Potterton 30Kw combi boiler fitted, old one removed along with the tank, full line flush and TRV's fitted for £1700. Two blokes, two days work and a hole knocked through the wall, flue fitted and bricked up etc.
It's a small house, 5 rooms/5 radiators and a shower and the boiler is way more than needed but i run it at around 70% and reckon that will increase it's lifespan, rather than a smaller boiler run flat-out.
Posted : 25/11/2011 4:47 pm
Just finished today and cost £3000 all in.
Posted : 25/11/2011 5:08 pm
what was that for tommid ??
Posted : 25/11/2011 5:12 pm
there seems to be a big variation in prices 1.5-3k+. people aren't putting what they ar getting for their money!
Posted : 25/11/2011 5:16 pm
 Bear
A filter will not do the job of an inhibitor.
Posted : 25/11/2011 6:00 pm
Well, I'm basing my comments on actually [b]asking[/b] two different WB accredited installers and that 5 year warranty being their response. Maybe you sell it and the others incorporate it in their install price? My installer doesn't offer this so you get the standard 2 year warranty.
Posted : 25/11/2011 8:40 pm
the 5yr warranty is an insurance policy available from wb through trained installers its 99
the magnaclean and fernox magnetic filters are not inhibitors but will be much better long term than a simple flush and a litre of inhibitor
regularly serviced in the first month the filter will withdraw all the circulating crud and act as a permanent defence for your boiler..
Posted : 25/11/2011 8:54 pm
last march we had an old combi ripped out, a new one insalled to a new position, a fancy one with wireless thermostat all in £1,700
2 year warranty on ours aslong as the installer does the service which was £50
Posted : 25/11/2011 11:36 pm
 Bear
A filter will not stop the chemical reaction between the metal, merely remove the product of it. And you need both a magnetic and mesh filter combined for proper filtration.
Posted : 26/11/2011 9:33 am
