Anybody got an inse...
[Closed] Anybody got an inset stove?
[#3279307]
We already have one woodburning stove which we love but we also spend time in another room that has a nice stone fireplace and a standard 16" open fire. but since getting the first stove I hate the way an open fire is so uncontrollable.
So I was thinking about putting an inset stove in - but do they give off more heat than an open fire?...I would have thought so but wanted to check!
Posted : 25/10/2011 12:02 pm
yes absolutely loads more, think of it ike a wood burnere enclosed in a box with vents at the top and bottom for the air to circulate out - not as good at heating the room [just as good at heating water if a boiler is fitted] as a wood burner but way better than an open fire.
You will notice the difference.
You could probably achieve as much putting a huge metal plate /chimney in /on your open frire though to radiate out heat]
It is far more controlable as well than an open fire
Would doend on cost and use tbh - there are deals on ebay as I did consider it for the same reasons as you but knocked the fireplace out in the end.
Posted : 25/10/2011 12:19 pm
