Great feeback guys, thanks.
(OT but what problems are you having with the HILO?A couple of things. It’s not very old, 2 months, so these things shouldn’t be appearing.
The major thing is: when fully raised raised, from fully lowered, there will be about 5mm of drop when sat on. This can be resolved by holding position, pulling lever, standing up, pulling lever, at which point it’s largely ok.
Other minor things: a ballache to set the pressure (must pull lever and pump simultaneously), doesn’t rise very fast, doesn’t raise fully if met with tiny amount of resistance (different from above, where it’s fully raised until sat on), stiff cable already (small but annoying as I lubed it), and probably something else I’m forgetting.
So for near £200 I’m not impressed…
