It is basically a Vauxhall diesel engine with 2 instead of 1 turbos
No it’s not – the 1.9 TiD & TTiD are both derived from the same Alfa Romeo unit.
Had a 56 Plate TiD saloon & a 10 plate TTiD Estate. The latter is a fantastic car for biking/camping etc – huge boot with a flat entry, great engine & spec & it drives really well (yes, I miss mine). There’s a user on here that was very disappointed that he didn’t have the funds to buy it when I had to change it earlier this year.
The saloon was okay space wise but getting a bike in was a case of seats down, wheel off & a bit of wiggling about. If you end up with a one I have a set of Saab roofbars in the garage you can have for the cost of postage.
Edit: I put 112k miles on the saloon & 95k on the estate and neither ever missed a beat or cost anything other than routine servicing etc. The only ‘negative’ was the tyre size – the 225/45 18w XL was a relatively rare one so could be a bit pricey (unless you knew where to shop).
