the sound still being occasionally sent to the headphone port after you pull the headphones out
That might be a physical cause, pocket fluff in the socket? That kind of soft-wear issue is difficult to patch.
Pretty sure it’s not physical/mechanical….but not 100% sure.
It does it if you have the Walkman app on, but the phone ‘asleep’. Pull the headphones out and it puts the Walkman on pause. But, if you then unlock the screen and hit play you get no sound out of it. But, you can plug the headphones in and it is still playing through the headphone socket.
If you then stop the music (hit pause), take the headphones out and then hit play again, it will play through the phone speaker. So it is fine when the Walkman app is active and the phone is ‘awake’, but struggles when the phone is ‘asleep’ with the app running.
retrorick – yeah I do need to check all my sync settings.
sadexpunk – Jellybean I think. Don’t think Kitkat is available for my phone; it’s getting on a bit.
