Kryton57 – Member
I’ve heard that some people get a Crema on thier coffee. Is this so and how?
In addition, how long does this increase stirring go on for? Im using the upside down method and stirring for about 30 secs before pressing.
I find it’s very coffee dependent. I have APs both at home and work. At home I grind the beans but at work I use pre-ground.
If the beans are from a pack which has just been opened, freshly ground and the water is the right temperature, you can get a half-decent crema. Which, of course, disappears the minute you adulterate the shot with water to fill up the cup.
I find sometimes wetting the coffee before adding the rest of the water can help to release the crema as well.
Every now and again on a newly-opened bag of ground I’ll get some as well, but it’s far more hit and miss.
That said, I like it fairly weak, so with less coffee there’s likely to be less crema.
