Advice on Kielder t...
[Closed] Advice on Kielder trails
[#2919713]
Anybody with local experience of Kielder care to give me a recommendation for a trail. The black looks a bit short, so I was trying to figure out which of the trails people would recommend for a decent 1.5 - 2 hour ride, with some technical stuff so that it's not simply a grind over distance(albeit scenic). Recommendations please
Posted : 06/07/2011 1:51 pm
The black isn't really a stand alone trail, its more like a harder option on the end of the red. If you want a Techy ride then do the red with bacl options. If you don't like gravel road slogs, miss out the section that goes right to the top of Deadwater Fell.
Posted : 06/07/2011 2:55 pm
That's good advice, the topmost loop is far too much work for a descent that's really just blasting down a trashed gravel road. It's quite fun in its way but not worth the climb.
Never ridden the Lonesome Pine route but the black/red Deadwater is ace IMO... Including its frustrating climb :mrgreen: Into the Valley and Dougie's Day Off are 2 of my favourite bits of trail anywhere.
Posted : 06/07/2011 5:52 pm
Thanks, much appreciated, looks like there will be rain.
Posted : 06/07/2011 7:17 pm
The lonesome pine is a bag of ringpiece tbf, archetypal scenic grind - not sure what the builders were thinking of really. It does seem to go through good MTB country, but you'd need a local to show you stuff off the marked track. Deadwater is good - really nice day I would probably go to the top as you'd get lovely views. Swerve it if the weather is not up to scratch.
Posted : 06/07/2011 7:34 pm
 jonb
Easy enough to do the deadwater red then climb back up to the bit where the black splits off to make it a bit longer.
Lonesome pine and bloody bush are nice xc loops but it you are looking for trailcentre thrills you'll be disappointed, it's pretty devoid of technical features.
Posted : 06/07/2011 8:08 pm
 grum
Red then black lime jonb said. The black descent is the best bit IMO, great fun.
Posted : 06/07/2011 8:47 pm
