>I have 2700 mAH batteires with totally different run times for example
Bear in mind that there will be some process variation on manufacturing – although they may have diffent runtimes both may well be exceeding the specified capacity (= runtime) but to a differing degree.
Re mAH – it's a measure of capacity (if you looks at the units, it's current x time) – eg a 2700 mAH battery/cell may provide 2.7A (2700mA) for 1hr, or half that curent for two hours, or a quarter for 4 hours, or twice that for a half hour – in each case current x time is the same.
Tho' that's not *quite* correct, the 2700mAH rating will be at one particular current, and it won't be a linear tradeoff (eg at one extreme you're not gonna get 27A out a battery for 1/10 of an hour, and at the other extreme with a very low current draw from the battery, it'll self-discharge before delivering the rated capacity – rechargables go flat left on the shelf)
