Had a funny crash today, over the bars and ended up with a broken finger. During this debacle, and I think as a result of the angle the front wheel was turned to, the front tyre spunked some of its latex out with a corresponding sound of relief. Is this fairly normal if the tyre gets a lot of pressure on the side? I’m new to tubeless, so anything to check for other than put a bit of latex back in the tyre (maybe?). No obvious damage to the rim or sidewall.
While I’m asking, the front tyre, a HR2, wobbles side to side when the wheel spins (did this from new so not a result of crashing today). The wheel is true, and the tyre bead even in the rim as best I can see – going by the uniformity of the hatched bit. Is this common? Tyre fitted wonky or a duff tyre? Back one is fine.
Many thanks.
