Thought we’d go seriously “budget” this season. So a set of used but immaculate Hed Jet6/9 wheels running tubeless Corsa Speed tyres#, and a plan for a wheel cover to convert to a disc. I needed a new front wheel so a disc was a little too much.
I was mulling over what to use for the cover, carbon fibre, abs, buy a ready made one (no Raltec anymore), and some measurements showed that I need to discs of only 24 cm radius. A nice tough, material suitable for fashioning into a cover – with low friction?
Teflon!!! Ordered two teflon oven sheets 50cm x 50cm for £9 each to trim down for next week’s Hillingdon TT. Will post pictures if they look even remotely reasonable. I’ll need an oddly-placed valve cover as the wheel is already very deep, or I could just peel back and retape the cover.
Quite excited by the prospect of some bike DIY – see last thing you made thread 😉
#Note – bought 80 mm tubeless valves, but still needed an extension for the rear – only Stan’s are threaded for deep section wheels, but the extender worked perfectly.
