davidtaylforth – Member :”I’d ignore the above and add 3 if you have a 68mm BB or 1 if you have a 73mm BB. Put them in whatever order gets you the best chainline, there is no set rule.”
as a professional bike mechanic, I’d advise you to ignore this advice^^
the non-driveside Shimano cup has considerably less thread depth than the driveside cup…
…and adding too many spacers to the non-driveside can leave your cup hanging off a couple of threads
potentially ruining your frame’s bottom bracket shell, and definitely ruining the bottom bracket cup 🙁
for 68mm its 1 spacer on the non-driveside, and 2 spacers on the driveside
for 73mm its 1 spacer on the driveside, and no spacers on the driveside
