I'm building up my new Pegasus and have a bit of a problem with the crank clearance. The BB is a 73 x 113 Royce Ti (the frame's BB shell is 68mm but this just means the cups are a bit proud of the shell, no big deal). The problem appears to be with the 113mm axle. My Middleburn RS7 cranks install just fine, but once fitted there's only about 3mm clearance between the crank and the chainstay (and this is before tightening them up after a ride or two). I can actually flex the thing enough by hand to get the crank touching the chainstay.
Middleburn cranks are apparently designed to have a correct chainline with a 113mm axle, but it looks like I'm going to have to go with at least a 118mm axle on this frame. Any thoughts on whether this will screw up my chainline once the bike is all built up? Cheers.
