So I bought a Fireeye Hot Trail 29er frame a while back and have slowly been collecting bits to build it up. Build is going to be short stem wide bars, wide rims etc. so it’s following all the trends/fashion 🙄
I’ve got to the point where I’m buying forks and I’m trying to figure out what I need/want.
The frame is recommended to run 130-150mm travel up front, I’m thinking of going dead center and getting something with 140mm.
I’ve bought wheels with a 15mm front hub, so that’s a requirement.
I originally wanted to run pikes up front as I have those on my other bike and they’ve been the go to enduro/AM/do-it-all for fork a while.
I’ve also been eyeing up revelations, but I’m worried they’ll be too spindly.
Then out of nowhere this Yari fork has appeared and then there’s also Sektor gold RL’s to think about too.
I havent really looked at the fox range as they’re usually really expensive, but I’m not adverse to them. Same with other brands.
Budget is going to be topping out a £400ish so Pikes will probably be secondhand unless there are mega deals about.
Also there’s this offset thing, I’m assuming “standard” will be fine?
Please help lol.
