Home Forums Bike Forum wahoo 35mm mount
Viewing 12 posts - 1 through 12 (of 12 total)
  • wahoo 35mm mount
  • dandasbike
    hello, anybody had any joy finding a suitable mount for an element bolt on mtb bars? not too keen on paying 50 quid for the k edge one, thanks.
    ta11pau1
    Barfly mount can be had for £35 and includes adapters for all computers/gopro.
    djflexure
    K edge top cap mount perhaps?
    argee
    I just use the circular one that comes in the box that you zip tie to the bars, works well as it means the 31.8 mount is on the other bike permanently.
    dandasbike
    i have a oneup EDC so a top cap mount is out
    stevious
    +1 bar fly mount. Come with a shim too if you need to swap bars. Be warned it’s designed to put the computer over your stem so it looks silly If you put it in ‘out front’ mode.
    huckersneck
    ta11pau1
    Doesn’t look as good as it would over the stem but it works well.
    stevious
    Ha! Mine is out front as well because I haven’t trimmed my steerer all the way down. I guess it just looks weird compared to the aero mount on a road bike.
    Mister-P
    Having my GPS offset like that would drive me nuts.
    spooky_b329
    I went for a loop mount that puts the Wahoo over the stem.
    K Edge was £45.
    Superstars version is utterly rubbish as the Wahoo just spins and falls off (same as the HUP branded one)
    Finally settled on this bargain which also holds the Wahoo firmly, and the hinge means you don’t need a 10mm spacer to ensure it clears the stem clamp.
    dandasbike
    like the look of the loop mount one, i that off amazon? looks like one ive seen on there, cheers.
The topic ‘wahoo 35mm mount’ is closed to new replies.
