VW T5.1 factory fit...
VW T5.1 factory fitted rear window advice
8 Users
14 Reactions
Offline  matt_outandabout
Share this post
I've just ordered a replacement catch mechanism and freed up a stuck window.
Plan is to clean it all really well.
But what can I lube with - I was thinking silicone lubricant, maybe gummi-pfledge?
Any other advice on them - I gather they are a poor design.
Posted : 06/04/2024 7:10 pm
Offline  nickdavies
Share this post
Do you man the side window?
clean and lube with gummi-pfledge
all I do and never had a problem with them in 10 years , aside from they get a bit stuck when I’ve not done that for a while.
go easy on the handles when you do free them up.
Posted : 06/04/2024 7:17 pm
Offline  thegeneralist
Share this post
Shove them shut and fill them with silicone sealant, it's the only way to be sure.
Utterly shit design
Posted : 06/04/2024 7:25 pm
mashr, ready, Yak and 5 people reacted
Offline  phil5556
Share this post
I’ve got a couple of tubes of this https://www.housewaressidmouth.co.uk/product-page/carlube-silicone-multi-purpose-grease-20g-1
which I use for these kinds of jobs, a little goes a long way. Although having just googled it, looks like it’s not that easy to get hold of now.
Ultimately I had my windows replaced with aftermarket ones, which never leaked or got stuck…
Posted : 06/04/2024 10:03 pm
Share this post
They do seem poor - but we could do with the ventilation in the camper...
phil5556 and phil5556 reacted
Offline  Andy
Share this post
Are these the sliding rear side windows? I ask because I had them fitted to my converted panel van T5 and one of the latches has detached from the glass.Need to glue it back on. Does any one know whats the best glue for attaching a plastic latch to glass please?
Agree with MOAO they are much needed for ventilation. Have you got midge screens yet?
Posted : 06/04/2024 10:15 pm
Share this post
Mrs_oab is on it - looking at magnetic ones for side windows. We've already got high windows and skylight, but I'm not convinced the mesh is small enough to stop midges, so we're also looking at a velcro midge net for skylight...
Posted : 06/04/2024 10:24 pm
Offline  Andy
Share this post
Oh yeah you are a high top forgot about that! For side windows I am making some inset ones, maybe a bit of 3D printing, as looked at magnetic but they have to cover the whole pane, not just the crappy small bit that opens. kirivans do one but £££
Posted : 06/04/2024 10:30 pm
Share this post
Mrs_oab is handy with sewing machine, and magnets seem the answer....
Posted : 06/04/2024 10:36 pm
Offline  escrs
Share this post
If you have freed up a stuck side window then did you check to see how much rust was in the bottom?
My passenger side sliding window has started to rust but still works and hasnt leaked yet, the drivers side sliding window has completely rusted, leaks lots and ive siliconed around that one for now
To get my passenger side window running freely i just used some silicone spray and now open it a few times a month to keep an eye on it
Posted : 07/04/2024 7:07 am
Offline  BigM
Share this post
I binned mine off and got new windows from Camper Glass. Original one leaked constantly.
Posted : 07/04/2024 10:46 pm
Share this post
None!
It was stuck through no use due to a broken catch. Seemed to just be stuck to the weather seal and dirt on the lower track.
Posted : 08/04/2024 6:35 am
Offline  hot_fiat
Share this post
Make sure the drain leak catching holes are clear.  The whole design is a shambles: who the hell designed a car window to deliberately leak? Then the water it lets in pisses all over the integrated blinds and covers them with aluminium oxide.
Posted : 08/04/2024 10:32 am
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
