volume terminology
[Closed] volume terminology
17 Users
I'm going to blame 2 weeks off, but seem to have forgotten / be doubting basic volume terminology
20m3 (superscript '3') = 8,000 cubic metres (20m x 20m x 20m) and not 20 cubic metres.
Posted : 06/01/2022 3:46 pm
 Sui
20m3 could be 10x2x1
20x20x20 would equal 8000
Posted : 06/01/2022 3:49 pm
 Sui
i work with chemicals so everything is done in litres, cubes and tonnes
Posted : 06/01/2022 3:50 pm
 Sui
ill redo that,
20m3 is 20,000 litres in liquid terms
8000 cubic meters = 8000m3 - that would be 8,000,000 litres
Posted : 06/01/2022 3:52 pm
20m3 is twenty cubic metres.
Or 30 years in construction is going to cost me a lot shortly 😖
20m^3 is 20 cubic metres and 20^3m is 8000 metres isn’t it?
Posted : 06/01/2022 3:53 pm
And twenty metres, cubed is 20x20x20 metres which is 8,000m3
Posted : 06/01/2022 3:54 pm
If someone asked me for 20m³, I'd expect they wanted enough material to fill a hole 20m long, 1m wide and 1m deep.
Posted : 06/01/2022 3:55 pm
marcus
20m3 (superscript ‘3’) = 8,000 cubic metres (20m x 20m x 20m) and not 20 cubic metres.
Nope. 20m3 is X*Y*Z=20m3
Posted : 06/01/2022 3:58 pm
The standard comparator for volume(*) is Olympic Swimming Pool.
An Olympic Swimming Pool = 2,500 cubic metres.
So what you have = 8/2.5 = 3.2 Olympic Swimming Pools
*for length, it's London Bus, for area it's The Size of Wales.
Posted : 06/01/2022 4:01 pm
20m^3 is not the volume of a twenty metre cube
Posted : 06/01/2022 4:04 pm
Rubber Buccaneer - That makes sense. Would we all agree ?
Posted : 06/01/2022 4:10 pm
20m3 ≠ 20 cubic metres!
Posted : 06/01/2022 4:17 pm
It most certainly is in my world, and is used as such day in day out.
Posted : 06/01/2022 4:21 pm
i scoff cake yes it does
rubber buccaneer (and stumpy and onzadog) is correct
although really you should have a space between the number and the unit
20 m^3 means 20 metres-cubed which is English parlance is twenty cubic metres
If you mean 20 m by 20 m by 20 m that would be 8000 m^3 or 20^3 m^3.
Indeed, 20m3 is 20 cubic metres. It is not the volume of a cube of side 20 metres, which would be 8000m3.
Trust me I’m a doctor (of engineering). Don’t get to say that often enough sorry 🙂
Posted : 06/01/2022 4:24 pm
20 m3 = 0.008 Olympic Swimming Pools
or
20 m3 = 3450.5 footballs
or
20 m3 = 38197.1 grapefruits
or
20 m3 = 109134.6 chicken's eggs
or
20 m3 = 238731.9 wallnuts
Source: https://www.theregister.com/Design/page/reg-standards-converter.html
edit: Tried to use superscript 3s but failed. 🙁
@goldfish24 20 to the power of 3 is indeed 8,000 and that's what I'd assume 20m3 meant.
Posted : 06/01/2022 4:32 pm
it means whatever the person asking for it wants unfortunately 🙂
see also biannually
Posted : 06/01/2022 4:33 pm
Anyway, 20m^3 of concrete is quite a big patio. Did you fall out with all the in-laws over Christmas?
Posted : 06/01/2022 4:43 pm
It's almost 50 tons of concrete. That's a lot of wheelbarrows!
Posted : 06/01/2022 4:50 pm
@goldfish24 20 to the power of 3 is indeed 8,000 and that’s what I’d assume 20m3 meant.
Gotcha, I understand the confusion.
The difference is the position of the superscript 3 that none of us can manage to actually superscript on this forum.
20m^3 reads as 20 metres cubed.
The unit of metres is cubed. Ie the unit is metres cubed and the quantity is 20 of them.
20^3m reads as 20 cubed metres.
20 cubed is 8000. So it’s 8000 metres. Linear metres, not cubic metres.
Posted : 06/01/2022 4:52 pm
What's that in cubic Kylies?
Posted : 06/01/2022 4:54 pm
@goldfish - yes I see your point; M3 should be understood as a unit, not a formula.
Posted : 06/01/2022 4:55 pm
Bingo you got it
Posted : 06/01/2022 5:00 pm
 loum
20m³ is 3 wagons of concrete
20³ m³ is about 1200 wagons of concrete, or 100 wagons on turnaround for a double shift.
Posted : 06/01/2022 5:07 pm
