Varia Seatsray Moun...
Varia Seatsray Mount
5 Users
3 Reactions
Offline  honourablegeorge
Share this post
Anyone got an alternate mount for the varia? Had a big saddle bag on at the weekend, so left the Varia at home, really missed it on the road bits.
Posted : 29/08/2023 7:16 pm
Offline  oldnpastit
Share this post
The radar goes through saddle bags, so you can just put it in there or a jersey pocket pointing the right way.
I've also got a 3d-printed mount I bought from someone on ebay which is pretty decent.
Posted : 29/08/2023 7:27 pm
Offline  Pickers
Share this post
I have two options for when I’m carrying luggage.
Just a saddlebag then I use a spare 1/4 turn Garmin mount from a computer, ditch the rubber spacer and use the two shortest O rings to clip it to the little loop on the back of the bag. I was sceptical too on this but mine has stayed put for months.
If I’m using the rear rack then I’ve just bolted on one of the 1/4 turn mounts from a direct headset topcap mount - they have a countersunk bolt hole that doesn’t interfere with the Garmin unit.
Lastly I also stuck a plastic boss on the back of my Varia for a lanyard - why don’t they come with this from the factory?
Posted : 30/08/2023 6:30 am
Offline  Jason
Share this post
On my road bike I use a PRO saddle that has a screw in mount for accessories underneath.  I have a GoPro mount fitted to this, then a short extension arm, then a Varia mount with a GoPro fitting in the back.  This way I can use a saddle bag, and have the Varia firmly mounted behind the saddle.  Works well for me.
Posted : 30/08/2023 8:19 am
Share this post
Restrap just launched a wee thingy, might work nicely with a band on Garmin mount
https://eu.restrap.com/collections/accessories/products/light-mount?utm_source=Klaviyo&utm_medium=campaign&_kx=ZAiWzxerjl6ZzPlwugJtjXcbe7-rW8--cHG_e-nWdOY%3D.W2LzAY
Posted : 01/09/2023 1:44 pm
Offline  TiRed
Share this post
There are a few extended saddle mounts to set the Varia behind the saddle pack. I’d miss mine too.
Posted : 01/09/2023 1:46 pm
Share this post
It's this bag I'm using, so seatstay is better I think....
Posted : 01/09/2023 2:09 pm
