Home Forums Bike Forum Understanding Maxxis tyres
Viewing 15 posts - 1 through 15 (of 15 total)
  • Understanding Maxxis tyres
  • johnhe
    I recently Thought that I might fancy a new tyre. I had minions many years ago and liked them a lot, although I’ve been running Spesh tyres for the past few years. Anyway, I went onto the CRC website and browsed the Maxxis section. Good grief – there are about 20 different variations of Minions alone.
    Can anyone please explain in simple terms what DHF, DHR and all that jazz means? In my faulty memory, I thought it was simple a case of choosing single or double ply!
    v7fmp
    johnhe
    Magic, thanks.
    honourablegeorge
    DHF/DHR = downhil front/rear, but the rear is a really good front, and they’re not just for Downhill these days. They’re equivalent to the Spesh Butcher
    Casing, in order of toughness goes EXO -> EXO+ -> Double Down -> Downhill(Dual Ply)
    Compound in order of stickiness is Dual -> 3c MaxxTerra -> 3c MaxxGrip
    WT means wider tyres for 30-35mm internal rims, you can get away with a bit narrower
    Tyres in my shed in order of dry to wet: Minion SS -> Aggressor -> Dissector -> Minion DHF/DHR2 -> Assegai -> Shorty
    You can’t go far wrong with a DHR2 Rear, and a DHF front
    fossy
    +1 for DHF and a DHRII. Really good predictable tyres 3c Maxx Terra EXO for general trail riding. Some say a little draggy, but not noticed (other than tarmac) but general grip is really good, especially off camber. I’ve run them the past 12 months. Rear starting to wear a little as I’ve been riding loads since lockdown.
    binman
    The tyres are also slightly different across sizes. A 2.6 DHF is less knobbly than a 2.5WT for some reason.
    oikeith
    If the tyre isn’t branded as 3c this or that then it is dual ply I have recently found out!
    StuE
    Originally DHF was downhill freeride and DHR was downhill race not front and rear,not sure if that still applies
    https://singletrackworld.com/wp-content/uploads/2017/07/review-maxxis-minion-dhf-dhr-ii-wide-trail-3c-tyres/
    MartynS
    I’d posted the other week that I seem to be the only person in the world that thinks maxxis tyres are a bit… well…. crap…
    minion 2 DHR 3c exo 2.4 on the back. 3 rides, 4 punctures. 2 right by the bead/rim join. One sidewall split, one tread split.
    Got some spesh tyres on order. Had very few problems with them in many years using them on my old bike.
    honourablegeorge
    StuE
    The original DHR was “Dowhnhill Really Don’t Want to be Using That”, was a crap tyre.
    tomhoward
    Back in 2008 folk were referring to them as front and rear, it’s only recently (ish) that folk are saying they used to be freeride and race (which seems an odd use of F and R, why not just use totally different names if they were for different disciplines)
    It’s def front and rear now, according to maxxis.
    nickc
    Great post from @honourablegeorge that explains everything you need to know! The DHR2 and DHF combo for pretty much anything. Get the EXO+ Maxterra versions for all round riding and you’ll not regret it, although if you can get hold of them in EXO+ and maxterra the assegai is a good swap for the DHF.
    bikesandboots
    Recently saw a useful-looking chart in this article – gives range of suitable surfaces for each tyre, and ratings for cornering and rolling resistance.
    https://www.vitalmtb.com/features/The-Complete-2018-Maxxis-Mountain-Bike-Tires-Guide,1928
The topic ‘Understanding Maxxis tyres’ is closed to new replies.
