I picked up a lovely Indy Fab Ti Deluxe frame off the classifieds a while ago, some folk may remember it (from TheSwede, it featured on the 'Fanny Basher' thread 😆 ) Anyway, I've now gotten around to building it up, the plan being to (for now) run it as a rigid 69er with an alfine (yes, I do use these hubs a lot in my builds!!) rear end. In order to easily run the alfine, I've bought a Forward Components EBB.
So, I've gone to fit the EBB cups and have run into a problem… the drive side cup goes in fine, but the off-drive side only goes in around 2-3 turns and then no further 🙁 So it would appear the threads on this side are mucked up (though can't really tell visually!). I've checked with TheSwede and he's said that when he's removed BB's in the past (Raceface ones) he's noticed a little aluminum swarf from the BB thread, so this suggests the Ti is cutting a new thread as the BB is installed?
The trouble for me is that the cups on my new EBB are machined from 'high strength heat treated stainless steel', which I'm thinking is too tough for the Ti threads to recut. I've taken it into my LBS (Mosquito, who are an IF dealer) and they can't re-tap the threads apparently, because it's a Ti frame it needs a tool they don't have??
So, they've suggested sending the frame off to a UK based Ti frame builder to have the BB re-tapped and faced, they reckon it'd cost around £30-£50 inc postage or so to do this.
The other option, of course, is to get a 'little' more forceful on the BB shell… basically using brute force to screw the shell in… but will the Ti be able to cut into the stainless BB shell do you think? Or will it all end in tears and a jammed BB shell (or worse)?
Just wondering what the good folk of STW would do/suggest?
cheers 🙂
