Home Forums Bike Forum the cobbler-is it rideable?
Viewing 5 posts - 1 through 5 (of 5 total)
  • the cobbler-is it rideable?
  • turbo1397
    Hi folks.One for the scottish STW. Has anyone done the cobbler? i know it would be mostly hike-a-bike up, but it looks quite good on the way back down.. ?
    creagbhan
    Arrochar Alps The Cobbler MTB Scotland GoPro: http://youtu.be/qj7yCgiLo4E
    turbo1397
    I take it you just follow the same path back down as you push up?
    Nobeerinthefridge
    I would only do the last section, where the path turns left up to the summit if you really want to say you’ve been there, and it’s a clear day for the views. Otherwise, turn there and go back.
    It’s a cracking descent, maybe a dozen or so waterbars that you won’t get over, but a belter. When you get back to the fire road at (almost) the bottom, where the wee bench is, don’t carry on down the rest of it, head left, as if toward coire grogain, and look for a wee descent on your right after about a mile, it was marked with a wee pile of stones last time I was there, do that instead.
    It’s quite short though, but combine it with the coire grogain loop for a days biking that’s worth the drive.
The topic ‘the cobbler-is it rideable?’ is closed to new replies.
