Home Forums Bike Forum Tapered steerer into straight headtube
Viewing 12 posts - 1 through 12 (of 12 total)
  • Tapered steerer into straight headtube
  • ruggerbugger
    Has anyone put an Ec44 bottom cup into a straight head tube & then run a tapered steerer fork in it? Any problems/issues? Is it structurally OK? Struggling to find a new fork for my old winter HT.
    Thanks for any input👍
    andyl
    do you have a straight 44mm ID head tube?
    fd3chris
    If not then you really are ruggerbuggered!
    nickjb
    If it’s a 44mm head tube then it’ll push straight and be fine. It may raise the front end a tiny bit but not enough to notice. Basically it’s fine. If it’s an old school straight steerer head tube then it would not fit
    Daffy
    As above. Classic 1.125 headsets are EC38. EC44 is for straight 44mm inner diameter headtubes and allows them to use a 1.5>1.125 tapered steerer. i.e. Chris King Inset 7.
    ruggerbugger
    Not sure what it is to be honest, will have a look. Its a trek excalibur 9 2016. Thanks for the info fellas, especially fd3chris😜
    andyl
    1-1/8″ threadless, semi-integrated, semi-cartridge bearings
    Sounds like you may have a 44mm ID semi-integrated but not being designed for an external cup might mean that the 44mm ID area is quite shallow and not enough room for the headset to slide into properly. An external cup will also add stack height.
    scotroutes
    https://archive.trekbikes.com/ca/en/2016/Trek/x_caliber_9#/ca/en/2016/Trek/x_caliber_9/details
    No tapered forks going in that.
    Poopscoop
    Blimey, that’s a pretty new bike to be tied to just fraught steerer!
    Poopscoop
    ^^ Freudian!
    rOcKeTdOg
    this approach might work…
    timoth27
    Like has been said above it just depends on how deep the recess is in the frame (I have a giant frame that Is only 7mm deep) but as far as I understand it “semi intergrated” is the same as integral and so yes you should be able to fit an ec44
    https://www.hopetech.com/wp-content/uploads/2014/03/HOPEHEADSETS2011Web.pdf
The topic ‘Tapered steerer into straight headtube’ is closed to new replies.
