Yes I’m turning it the right way.
No, really, I’m sure.
Got a cheap ebay special as part of a fixie build. I’ve had the hammers, heat guns, grinders and other fun tools out and have finally stripped the frame of parts fitted without grease 30 years ago.
I’m stuck on a pedal though. Given this has cost me a good spanner and a few hours I could probably just buy another crankset and be done with it but this is now about stubborn pride.
Any tips for removing it. I’ve tried penetrating oil, grinding flats, putting it in a vice with a 5ft scaffold pole. All failed. Cola, ammonia – anything else. Can’t drill it as the steel is too hard and I’m not buying a drill bit.
