SRAM Guide barb/oli...
[Closed] SRAM Guide barb/olive
 st
I'm shortening the brake hose on a SRAM Guide R but am stuck on finding new olives and barbs. All the usual places I'd check are listing Avid ones only.
I remember using the screw in barbs on Juicys way back but this Guide R has a red coloured olive and what looks more like a Shimano push in barb.
So do I need to keep looking for a like for like replacement or do Sram brakes still use the old style barb for retro fitting?
Ta.
Posted : 23/02/2017 7:49 am
Pretty sure they use standard Avid hose barbs, unless you have one of the levers with the 'stealthamajig' fitting which usually has a red-anodised olive
See below:
[img] http://www.dhfr.ru/forum/attachments/61207/ [/img]
Posted : 23/02/2017 2:19 pm
I used a shimano olive and push in insert in my sram rival one caliper when I should have really used one of the above.
Its hasn't leaked or been a cause for concern.
Some here £2.38:
http://www.ebay.co.uk/itm/AVID-OLIVE-AND-BARB-HYDRAULIC-COMPRESSION-HOSE-DISC-BRAKE-SPARES-/272015116361?var=570919964682&hash=item3f555d4849:m:mVpYCUUF2rk6rKJEClgt__Q
The screw in inserts are much easier to use
Posted : 23/02/2017 3:24 pm
 st
Thanks guys. Looks like I have a stealthamjig so I'll try to reuse the bits which I thought were scrap!
Posted : 23/02/2017 3:45 pm
You won't be able to reuse the red compression fitting, just like you can't reuse a regular olive.
According to the SRAM blurb below, the thingamajig is backwards compatible, so, as above, you'll probably be able to use the regular bits.
SRAM Stealth-a-majig is a hydraulic brake olive and barb design that allows OE manufacturers to assemble their bikes with hydraulic brakes and eliminate the need for a bleed procedure on internally routed bikes.
With the introduction of Stealth-a-majig, there is a new olive and barb that must be used to properly engage the brake. This olive and barb is completely backwards compatible with any other SRAM or Avid brake.
Posted : 23/02/2017 4:09 pm
Pretty sure we've got them in at The Trailhead in Shrewsbury if you're struggling to find them
Posted : 23/02/2017 8:29 pm
