It is possible to run proper UST tyres on UST rims without sealant – the special UST bead is airtight without needing sealant (the advice up there is wrong), the cost of making the tighter tolerance special bead is one of the main reason dedicated UST tyres are more expensive.
However, UST tyres are heavier (although they do have airtight and toughr sidewalls). The most popular way of going tubeless, and my preference, is for a cheaper and lighter “normal” tyre with either a UST rim or a standard rim with rimstrip or sealing tape (depending on rim type) and a scoop of latex to get the puncture resistance referred to up there.
A UST tyre on a UST rim with latex is the most robust, but heaviest and most expensive way of achieving a tubeless setup
Whatever way you choose, the reduced rolling resistance and pinch-flat-proof-ness of the setup should see you smiling.
Hope that helps
Rob
bigrobracing.co.uk
