Singlespeed Tension...
[Closed] Singlespeed Tensioner
Now the bad weather has well and truly arrived I'm going to convert my Solaris Max to singlespeed for the winter.
I've rode singledpeed quite a bit in the past but always had frames with sliding dropouts and the likes. The Cotic will need a tensioner of some description.
Any suggestions?
Are the Alfine tensioners any good on MTB's?
Posted : 04/10/2020 5:52 pm
I’m a massive fan of VeloSolo
https://www.velosolo.co.uk/shopsingle.html
Posted : 04/10/2020 6:04 pm
@eddiebaby do you think that would work as a get-you-home rescue measure in the event of braking a rear mech without shortening the chain?
Posted : 04/10/2020 6:08 pm
I have no idea! I am sure there far more experienced singlespeeders than me on here.
Edit: I’m pretty certain it wouldn’t. It only takes up a small degree of slack. Not the mass of length a modern mech has to handle.
Posted : 04/10/2020 6:12 pm
My first SS is a year old this month and I've had good experience with the Surly tensioner.
Posted : 04/10/2020 6:24 pm
I've got the one from CTBM (or Bikemonger as is now) and it's decent enough. I needed to put threadlock onto the bolt holding the jockey wheel the other week but apart from that it just works.
Posted : 04/10/2020 6:40 pm
Are the Alfine tensioners any good on MTB’s?
I'm using one and like it. I couldn't use a push-up tensioner because too much slack to take up. I'm running narrow wide chainring and rear cog so can't use a half link. I don't like the push-down rear tensioners because of lack of chain wrap.
Main disadvantage is chain slap - it's like going back to a non-clutch rear mech. Haven't dropped the chain though.
Posted : 04/10/2020 7:20 pm
I've got a black Surley Singulator in my spares box. PM me if it's of interest.
Posted : 04/10/2020 7:38 pm
I'd just run a stinger style roller on the ISCG mounts.
No crappy springs to rely on and out of the way of rocks.
Posted : 04/10/2020 7:49 pm
You don't need to take up a massive amount of slack, only one link's worth. Just shorten the chain to suit. That pseudo-derailleur of sl2000`s is total overkill.
Posted : 04/10/2020 8:24 pm
 Del
as multispeedstu above 😉 a bb mounted roller works very well. out the way, run the bolts a smidge loose and you can just give it a tap to increase tension, and the rear works exactly as it did before if you need to get the wheel out for some reason. did me for a couple of years on one frame. blackspire less than 20 quid. very simple.
Posted : 04/10/2020 8:28 pm
Might be worth trying to get a magic ratio on your Solaris Max before buying a tensioner? There are some calculators online where you put in your chainstay length and chainring size and it'll show you how close certain ratios get to not needing a tensioner. Looks MUCH cleaner if possible!
Posted : 04/10/2020 8:49 pm
 ctk
I've used loads and like the Surly one.
Posted : 04/10/2020 10:34 pm
Initial chain, sprocket and chain ring wear, (probably more correctly bedding in) happens surprisingly quick, so your magic ratio, nicely tentioned chain will be flapping around like a pro's pants after a couple of weeks without some adjustment.
Posted : 04/10/2020 10:51 pm
You don’t need to take up a massive amount of slack, only one link’s worth. Just shorten the chain to suit. That pseudo-derailleur of sl2000`s is total overkill.
That comment of mine was about using a tensioner as a mech replacement for riding home with un shortened chain.
All my SS bikes have EBBs.
Posted : 05/10/2020 1:40 am
How about a Rohloff or Paul Melvin tensioner?
The only non EBB or sliding dropout singlespeed I had used a Surly. It wasn't strong enough to prevent chainslap but think that'll be the case with anything relying on a spring and no clutch. Not used one but I magine one of the fixed in place roller types would be best at stopping that.
Posted : 05/10/2020 3:27 am
The single arm Alfine tensioner CT-S500 has the wrong chainline for singlespeed use (from memory, I'm sure it wouldn't go anywhere near).
If you try s magic ratio, just set it up with a chain thats already done a few hundred miles, makes a big difference. And you can ride a singlespeed with a surprising amount of slack chain 🙂 Finally, if you go magic, just check your rear wheel does not have a rearward path to take it out, otherwise you'll be removing the quicklink every time you want your rear wheel off.
Posted : 05/10/2020 7:37 am
I ended up buying a second hand 10spd SLX clutch mech and tensioning it with an old spoke (can also use a short run of old cable). No more dropped chains or chain slap, and it only cost a tenner!
Posted : 05/10/2020 8:09 am
Its been some time since I ran a singlespeed, but I cant see the options will have changed much.
Whilst some of my chums constantly faffed with magic chainstay lengths and sliding drop outs as the chain wore, I just bashed on a Rolhoff tensioner which took care of all that crap and just let me ride. Its got a really strong spring too, so no chain slap either.
Posted : 05/10/2020 9:17 am
Is there any reason not to run a ISCG chainring tensioner (if you have one spare)?
Posted : 05/10/2020 9:46 am
The main reason was that I never knew such a thing existed 😀
To be honest they look like a pretty cheap and easy way of doing it and doon't look too bad either. Just need to find somewhere that has stock of them now!
Posted : 05/10/2020 10:08 am
None at all and they make dropping the rear wheel out dead easy cos the chain's tensioned at the other end-
Posted : 05/10/2020 10:15 am
 Del
does depend on ratios, chainstay length, and design of your guide as to whether you'll have sufficient adjustment without using a half link, and then you can only do that if you're not using a thick/thin chainring. the other option is to get busy with the drill/file/mill on your tensioner but it's not like they're complicated things. 😀
Posted : 06/10/2020 8:37 pm
kayla1
None at all and they make dropping the rear wheel out dead easy cos the chain’s tensioned at the other end-
That's me sorted then 😉
Posted : 06/10/2020 8:52 pm
For those "singlespeed it, to get home" moments, just shorten the chain.
Assuming, of course, that your multi-tool has a chain breaker, and you carry a couple of quicklinks
Posted : 10/10/2020 7:49 pm
Magic ratio on this turd, with one of @kayla1 awesome chainrings up front.
I am pondering a slight reduction in gear size which would necessitate a tensioner. Nice to read of the various methods.
Posted : 10/10/2020 9:31 pm
doomanic
It would be less faff to carry one of those tiny multi-tools with a chainbreaker, and shorten the chain to singlespeed it.
Carry some rubber gloves as well. 🙂
As for tensioners, the best tensioner is no tensioner.
There's lots of tricks to Magic Ratio a singlespeed.
Posted : 11/10/2020 1:25 am
