Home Forums Chat Forum shed bases
Viewing 9 posts - 1 through 9 (of 9 total)
  • shed bases
  • rOcKeTdOg
    concrete, slab or eco-grid, which is best?
    Stoner
    Insulated slab.
    So that when you get kicked out of the house you can live in he shed in comfort.
    rOcKeTdOg
    insulated how?
    Stoner
    hardcore, blinding sand, DPM, 100mm kingspan/xtratherm, 50mm screed, underlay, deep shag pile.
    whats your budget again?
    restless
    mine sits on a load of rubble, straightened up with a few wedges of wood.
    hasn’t budged in 9yrs 🙂
    allthepies
    Slab on sand worked for me.
    rOcKeTdOg
    shed will be upto 20x10ft, so that sounds a bit over the top Stoner, i’ll wear two pairs of socks instead
    RobHilton
    carlos
    Reasonably level ground and 2×2 flags laid on sharp/grit sand in a lay one miss one pattern (chess board style) It halves the ammount of materials required, is easy enough to do, allows air flow underneath and not OTT but plenty good enough.
The topic ‘shed bases’ is closed to new replies.
