Rolhoff for gravel ...
Rolhoff for gravel riding?
There seem to be a few gravel bikes available with Rohloff; from Shand for example
How do these ride?
I assume their rear-heavy nature wouldn't be such a problem for gravel and light XC as it would for mtb proper, but I could be wrong... does a Rohloff require significantly higher rear tyre pressure for example?
And then there's the drag question. I've read loads about this and a lot of Rohloff owners seem to think the issue is overblown. There's also the lab test showing fairly negligible losses. But that didn't look at drag when coasting (I don't think), and if a Rohloff leads to cranks turning when walking the bike there's surely something there(?)
Finally, Rohloff on dropbars. This looks a nightmare and perhaps the biggest compromise?
Posted : 30/01/2023 4:43 pm
I'm a big fan but mine is on a flat bar mtb used for mainly gravel riding / touring.  I also had one on my tandem
I don't notice the extra weight in the hub at all.  I don;t run any higher pressures than I would otherwise but I don't run superlow pressures anyway
I don't notice the drag at all.  We did however have a very interesting discussion on here about drag and it would seem that at low power outputs the drag is not really obvious or an issue - at high power outputs it probably is.  So if you are going to be pootling its different from if you are racing.  I also think cadence comes into it so high cadence its less noticable.  Even if there is a bit extra drag does it matter unless you are racing?
coasting drag - IMO a non issue 'cos when you are coasting it doesn't matter at all - never notice it for sure and if you are only coasting downhill does a wee bit drag matter?  Yes spin the pedals with the bike on a stand then let go the pedals will turn but if you hold them it does not slow the wheel noticeably.  according to Rohloff its drag from the seals and you can lube them but I tried and it made no difference I could see
Drop bar shifter looks to be an issue. and don't forget the shift is horrible feeling anyway ( thats the worst aspect to me)  Various solutions to fit a shifter to drop bars but none look great.  I have not tried this
Remember the advantages as well -increased drivetrain life and massively reduced costs in replacement drivetrain parts, no chainslap / dropped chains / miss-shifts and being able to shift at a standstill and no vulnerable mech flapping about to get gummed up with mud, smacked off rocks etc.
Posted : 30/01/2023 4:57 pm
I'd be curious what problems you would be trying to solve on a gravel bike.
Obviously the attraction of a Rohloff on an MTB (for me) is removing all the exposed shifting gubbins, but is this as important on a gravel bike? Ditto performance in the mud, it takes some pretty serious CX conditions to really unship a gravel or CX drivetrain these days, in fact the only issue I've ever had is when the mud and twigs were so thick on my chainring that the chain stopped engaging on the teeth!
I think my personal objection to a Rohloff would be that I ride my gravel bike more like a road bike than an MTB, so any increased weight or drag would need clear and significant benefit.
I think I'd rather invest in as durable and efficient a 2x drivetrain as possible (e.g. Dura Ace chain, pay close attention to cassette ratios etc) and since we're talking Rohloff money I'd maybe even go for an electric front mech as I genuinely think Shimano's latest mechanical front mechs are a weak point in the GRX groupset.
Spend some of your considerable savings on a good hot wax setup like Molten Speed Wax which would help massively towards longevity and (in my subjective opinion only) probably also drivetrain drag.
Posted : 30/01/2023 5:08 pm
On costs - its a big upfront cost but it pays back over time with reduced costs of drivetrain wear.  Break even point depends on what you run but say 10 000 miles - 20 000?
6000 road / gravel miles on my shand now.  Chain is a bit worn but I think it will at least double that before needing to be replaced and then it will be just a chain.  Sprockets and chainrings last really well as they are full teeth and even then its one cheap sprocket and one chainring to replace
Posted : 30/01/2023 5:16 pm
As an owner of a Alfine 8, you could argue that as heavier rear wheel offsets the weight of suspension forks on an MTB. I never noticed it whilst riding.
Gravel...probably more noticeable on a lighter bike.
Posted : 30/01/2023 5:43 pm
There's another option - the Alfine 11 which you can also get Di2, it's got a far superior drop bar shifter that'll also work with hydro disc and it's about 1/3rd the price of a Rohloff.
If I was building an ultimate touring bike (like TJ), I'd go for the Rohloff but for anything else, it'd be Alfine every time, if only cos of the price difference.
Personally, like 13thfloormonk up there ^^, for a gravel bike I'd go for the best 2x drivetrain I could - GRX 800 Di2 for example. Or if you really are thinking of Rohloff money, try the new(ish) Classified Powershift rear hub for a single ring setup but the range of a 2x.
https://www.classified-cycling.cc/powershift-technology
They've recently got a few of the regular wheel brands on board with them so you're not restricted to their own brand wheel
Posted : 30/01/2023 6:02 pm
I own a rohloff. Would I let it near a gravel bike.... Would I sod.
Posted : 30/01/2023 6:09 pm
Reason for wanting one is largely maintenance
I don't really get any major problems with my gears, aside from the occasional complete failure in the snow. But I can't be bothered to clean and re-oil things so often anymore; after almost every decent ride in winter. Honestly I can't believe so many people are fine with degreasing a drivechain even weekly (but I guess if I had a garage workshop things would be slightly easier)
I don't actually cover that many miles nowadays, in large part as I find it too much faff. Pretty sure I'd ride more if I had something I could spray off and be done with. And this applies as much to my gravel bike as my mtb, as I tend to not ride really boggy stuff on the latter in winter (and it's single speed anyway), and I find plenty of mud on parts of my local gravel loop
Finally, and I know this comes up often, external drivechains seem such a terrible design. I find the idea of internal gears enclosed in an oil bath along with a constant chainline (and the elimination of all those wear and tear parts of conventional gearing) very appealing
Posted : 30/01/2023 6:49 pm
Add waxing to your chain and its a very low maintenance setup and the waxing seems to work well with the constant chainline.  Last summers ride it was only waxed once in 3000 miles
Posted : 30/01/2023 6:53 pm
Borrow one if you can.
On paper it's a great idea but it ruined an otherwise great bike for me that's lived and loved as a singlespeed ever since
Posted : 30/01/2023 6:56 pm
@crazy-legs
I remember seeing that powershift thing and getting excited about a lightweight 2-speed mtb, then I saw the price and propriety cassette...
Posted : 30/01/2023 6:58 pm
good idea.  Deffo marmite
Trailrat - I can imagine one making a nice light SS feel horrid 🙂
Posted : 30/01/2023 7:05 pm
I would say try before you buy if you can, it's alot of outlay.
the extra drag is minimal and beds in after some miles, servicing is a quick oil change once a year which is a ten minute job. If you do get one make sure the chainline is bang on or else you will get a noisy suonding hub, think coffee grinder.
There are solutions for drop bar shifters such as the Gebla Rohbox. Rohbox I've done a few of these now and they work very well, one shifter goes up, other side goes down, works really well with SRAM double taps.
Posted : 30/01/2023 7:10 pm
I have a rigid Shand Bahookie with the gates drive and carbon forks (bought as a recovery present to myself while recovering from a significant injury - broken back)
The spec has changed a bit since the pic but not too much (bars, stem seatpost, saddle & I moved to 29er rims too)
It's my perfect bike - tbh I'm considering ditching my gravel bike as this is just so good for most of the stuff I do (except fast road riding and gnarly MTB'ing - I have other bikes for those things) - this is the one I reach for the most -
Limited maintenance and super easy to clean - I've had it 2 years - one oil change and new pads, that's it (in about 8,000 miles)
Shand
Posted : 30/01/2023 7:11 pm
lovely bike
Posted : 30/01/2023 7:52 pm
I've s Shand Stooshie wirh a Rohloff hub and Gates belt drive. I've had it for a tad under a year so far.
The difference in weight (or more over distribution to the back) can be felt when I pick it up in the garage. But once sat on it, absolutely don't notice. (Could argue it makes manual-ing easier ! But that's bollox / all in the head really).  An extra water bottle is the difference.
Same tyre pressures.
Im using it on easier  tracks / trails / quiet roads etc. Not decending Jacobs Ladder or doen potato alley off Hope Cross.
Gear shifting is a tad different to the road bike (it uses converted SRAM road shifters. One for up the other for down).  And you can't see what gear youre in by looking down ! But soon used to it.
I firmly believe those who think they can feel the loss of power in the hub are just imagining it in their head. No way somebody's arse and legs can tell a few watts difference. It's just that it makes a different noise so is noticeable on tarmac. Bet its impossible to tell once on gravel.  Like the opposite of giving them a purple paracetamol but tell them it's EPO - instant 30 Watts more power. So they feel.
With the zero maintenance Gates belt and near zero maintenance hub, I'm ready for the coming apocalypse and chain famine (-I've a couple of 25ml oil bottles bottles stashed away to keep me going til the end of time  !)  All I've had to do this year is pump the tyres occasionally, and 1x brake pad clean when they got really dusty last Summer.
Would I buy another? Absolutely.
Posted : 30/01/2023 8:19 pm
No way somebody’s arse and legs can tell a few watts difference.
except it diverges based on power . As tj alludes there is a greater difference at high end as it’s proportional.
One of the great things about crank based power meters is it brings data to the masses and removes it from the lab - even though a 105 left hand arm on an xT chain set has about 4mm clearance on my stay is that it’s quantifiable on a given route outside a lab at a given power - it takes measurably longer on a rohloff.
It was an interesting experiment after 10 years of ownership to clarify that I wasn’t making it up in my head.
Posted : 30/01/2023 8:28 pm
I don't know... I make no claims to big mileages or mega fitness (or currently even moderate mileages or *any* fitness) but I would swear the bike feels noticeably faster for those first couple of rides after the chain has been waxed.
Would be an interesting experiment if anyone had the time or inclination, from what I recall of having ridden hub geared bikes I would be pretty confident I could feel the difference through the pedals.
Posted : 30/01/2023 9:23 pm
Have a look on YouTube at CyclingAbout - Aussie touring rider who does semi-regular videos of his equipment, his riding etc. He's done a few videos on various hub gear systems along with some semi-scientific analysis. He's a big fan of belt drive and hub gear systems.
Posted : 30/01/2023 9:32 pm
@velocipede, that bike sounds and looks like a dream
@robertajobb, ditto
The Alfine Di2 is tempting, given the shifting and cost, but I don't like the sound of pedalling feeling mushy and the potential reliability issues
What I really want is a Pinion monstercross, but I don't want to be changing my whole bike again, after picking up a Wolverine last year that I really thought I'd keep for a few years (finally)
Posted : 30/01/2023 9:51 pm
 ton
just gone back to a 3 x 10 set on my Ti fargo, after 2 years (8000 miles) on a rohloff.
here is my twopenneth.
gear changes on rapidfire thumbshifters are faster and easier than a rohloff.
you do feel the weight in the rear wheel of a rohloff.
very hard to unweight the rear end with a rohloff.
the gears feel too far apart on a rohloof. never seemed in the right gear.
rohloff took zero looking after in 2 years. bit of oil twice.
i have done a week or so on gears (200 miles). bike feels nippier, easier to change gear and IN MY MIND nicer to ride.
as for putting a rohloff on a nice light fancy bike........ no chance.
Posted : 30/01/2023 10:30 pm
I can agree it  'feels differnent'.  There is a different noise and vibration to be heard / felt. BUT - actually more losses being 'measured' by the legs and butt cheeks - I still doubt it.
A nice well oiled chain with a thick lube SOUNDS smooth and efficient.  Feels better. But actually takes more power to move because of the said thick sound damping energy absorbing oil.
(And even if it diverges for those with the power of 6 Chris Hoy legs, it'll still be the same % - the engineer in me can't buy into the losses ramping up disproportionately as power increases, in a low speed gearbox. Arguably I may have agreed the % loss is worse at v low powers as its having to overcome stiction etc).
Anyway. As others have said, best thing if possible is to try before you buy. I agree it's not a cheap purchase. This bike for me is intended to last me until I'm permanently asleep in a 7ft long box.
Posted : 30/01/2023 11:01 pm
Pinion?
The geared hub system seems just a passing point on the way to the real winner of frame mounted internal gears.
I did really like my Alfine though. Zero maintenance in the 3yrs i had it, wading through British winters and gloop.
I'm just about ready to order a Pinion soon. I think that'll be a keeper.
Posted : 30/01/2023 11:14 pm
I had a Thorn Catalyst hard tail with a Rohloff. I loved it and didn’t notice any downsides. For some reason I then changed it for a Thorn Raven as I wanted to tour on it and the Raven was supposed to be better touring bike.
I never really got on with the Raven. So I sold it and put the ‘hoff on a custom Woodrup. It was a beautiful bike but I never really got on with it. So I moved the hub onto a Surly Troll. I was nearly back at the catalyst… but by then 26 inch wheels were beginning to seem slow compared to big wheels. So I bought an ECR. At that point I decided that the issue was possibly the Rohloff. So I sold the Troll complete and stuck a 12 speed on the ECR. I like it as it is!
I have no idea why I loved the first one and didn’t like the second so much. I recon though that a Rohloff is an inch many have to scratch. It has pros and cons. For some the pros win and they love them. For others it’s the other way round. Although I wanted to hate 12 speed, I must admit that I rather like it.
A few things… mine went back to Rohloff twice (in prob 25000 miles) due to play in the bearings (felt like loose cones). Sending back was annoying but the turn around is about a week.
I also had an issue with baggy chains that wore faster than the sprocket. It meant that the chain needed changing but the sprocket felt like crap with a brand new chain. I blame lots of sand on my commute.
I prefer eccentric BB to sliding dropouts or track ends. All have pros and cons.
I know derailleurs are a bit primitive… but I can take them all to bits and repair them without waiting for a service. I understand them. The Rohloff is a black box that I can’t take to bits!
Despite all the above, I suspect I may try a ‘hoff again one day. Or maybe a 3x3 or Kindernay?
Posted : 30/01/2023 11:31 pm
How do they solve the shifting problem? Last time I looked there weren't any Rohloff compatible brifters, has that changed now?
Posted : 31/01/2023 10:49 am
FWIW.. I had an Alfine Day One for a while and though it was a popular bike as a hardy winter commuter I didn't like how it rode off-road. The rear axle weight distribution and 35mm tyres weren't so good. On bigger 650B tyres now it's be better but it's still the practical option more than the way to go for an involving ride feel.
But I can’t be bothered to clean and re-oil things so often anymore; after almost every decent ride in winter. Honestly I can’t believe so many people are fine with degreasing a drivechain even weekly (but I guess if I had a garage workshop things would be slightly easier)
I ride min 10-12 hrs a week in winter and it's years since I used degreaser or a chain cleaner system. I swear too much degreaser use causes as many issues as lack of maintenance. Use a good quality wax lube like Fenwicks Professional which lasts well enough and doesn't need endless rounds of degreasing. I just let the chain run fairly dry then brush it off, the chain's usually grit free enough by that stage. Then re-apply it. Having lube inside the links is what counts.
Posted : 31/01/2023 11:15 am
I ride min 10-12 hrs a week in winter and it’s years since I used degreaser or a chain cleaner system. I swear too much degreaser use causes as many issues as lack of maintenance.
Aligns with my belief that folk are also applying far too much chain lube in the first place.
Posted : 31/01/2023 11:24 am
^ Agreed. It's not the chain surface that needs to be kept lubricated.
Posted : 31/01/2023 11:30 am
Danger! Danger! Thread transition to Chain waxing/what chain lube thread imminent 😎
Posted : 31/01/2023 11:47 am
We have 8-speed Alfine Di2 on the urban E-bike, lovely faff-free system once installed, very little drag and easy to service. the 8-speed Alfine hubs can be had for under £200 as well.
Posted : 31/01/2023 11:49 am
@jameso and @scotroutes, I also suspect degreaser causes other issues -- it's always seemed crazy to me to spray so much of the stuff so close to the freehub and various other bearings.
To be honest last week was the first time I fully degreased my drivechain for many months. I'd just gotten used to it always being a bit rough. Now after one ride it feels about the same.
I did try to use a minimal amount of lube for a while, well wiped down, but I found even a single ride of more than half a day was leaving it dry and squeeking. I also tried some kind of wax lubes some years ago and found it didn't last long, plus the instructions were to throroughly degrease before reapplying so I gave up fast
May be I'll try the Fenwick stuff for now (but possibly keep my eye out for a second hand Rohloff too...)
Posted : 31/01/2023 12:14 pm
I have a rohloff and use it across a homemade 140mm travel hardtail for bike parks and downhill trails and another homemade lightweight XC bike for long distance ultra type riding.
Can't say I notice the difference in weight or drag between the rohloff and my other bikes with normal gears. What I do notice is having to do no maintenance on the rohloff other than the occasional chain lube against having to keep the normal geared bikes clean to maintain decent shifting.
Mine has covered over 20,000 miles and has had no maintenance other than annual oil changes and a quick wipe down probably twice a year.
If it's for long distance rides (100+ miles xc type stuff) it would be the rohloff every day purely for reliability if nothing else.
Posted : 31/01/2023 12:32 pm
After having IHG for well over a decade I'd never go back to derailleur gears. I've had an Alfine 8 Charge Duster and a Rohloff on a couple of frames, currently on a Soma Wolverine. They've done me well on lots of singletrack, towpaths, road and gravel. Saying that I'm not a particularly technical, fast, or hard rider. The lack of maintenance, more reliability and simplicity is the real appeal for me. As others have said, try and borrow one or give a cheaper Alfine a whirl at first before the big spend.
Posted : 31/01/2023 3:16 pm
So it’s definitely a neat bit of engineering but surely you need to absolutely hammer through chains and cassettes for these to make financial sense, given a chain and cassette costs about 40 quid at the lower end?
Given even a poorly maintained chain and cassette that’s lubed once in a blue moon lasts 1000 miles, you’d have to be doing around 30k miles to offset the cost
That’s said, if it’s all about nice things then I can see the appeal, as it looks like a lovely piece of kit
Posted : 31/01/2023 7:40 pm
 ton
a rohloff disc set up on a decent wheel build is gonna be at least £1300 new i reckon.
that is a lot of new cassettes and chains, but you cant only change your cassette and chain can you ?
new chainring too. so cassette, chain and a single ring is what, £100 for some decent stuff.
changed yearly is 13 years running. i have a mate who still runs a 1st edition rohloff on a p7.
good value...... you decide.
Posted : 31/01/2023 8:11 pm
I can agree it ‘feels differnent’. There is a different noise and vibration to be heard / felt. BUT – actually more losses being ‘measured’ by the legs and butt cheeks – I still doubt it.
That's not what I said though. I said at a given power measured by a Crank based power meter over a fixed distance the time taken to cover the distance is measurably greater. Ergo there's loss in the system.
While my legs and butt cheeks did notice it intially the strain gauge in the crank and the stop watch measured it.
YMMV based on your use but it was enough of a disadvantage for racing I retired it to a leisure cycle
Posted : 31/01/2023 8:18 pm
new chainring too
wouldn’t you need a new chainring just as frequently with a hub gear system as well, unless it’s a belt drive set up?
Posted : 31/01/2023 8:34 pm
Being one of the few on here to have ridden an other wise identical bike with both an Alfine 11 Di2 and an 11sp, 11-40 cassette, also Di2, and having done so for over a month on each setup, I can tell you 100% that you can tell the difference. Not so much when pedaling, but when freewheling - 100%! Same bike, same rims, same tyres. There is sooo much more friction in a hub gear than in a freewheel, it's VERY VERY noticeable. Average speeds on the gravel bike commuter (Niner RLT9) were almost 3kph slower on the Alfine than on the cassette. Some of that will be weight, but not much. This was a month of commuting - 220km per week with around 2000m of climbing in all weathers. So almost 900km in each configuration. Actually much more on the Alfine as I ran it like that for almost 4 years.
Cleaning and lubing a chain takes 5 mins once per week. Totally worth it. I'd never go back to a hub gear except for as a short commuter with a belt drive. I'd NEVER let one near my MTB or Gravel bike. Both of these are supposed to be nimble and poppy - this is the absolute opposite of a hub gear.
The best analogy I can give of a hub gear is a rubbish steel frame. It's just dead and heavy and cumbersome - yes it has utility and cheapness, but that's it. Life's too short.
And whilst an Alfine is long lived, my current GRX Drivetrain is at 13785km and is still on the original cassette, chainrings, jockey wheels, but has had a new chain. Again - all weather riding.
Posted : 31/01/2023 8:35 pm
 ton
no mate. my raceface nw chain ring had no wear after 8000 miles.
i read somewhere a good chainring would do 50,000 miles then rotate it 180 degrees and do the same miles. same for the sprocket on the rear.
Posted : 31/01/2023 8:48 pm
my current GRX Drivetrain is at 13785km and is still on the original cassette, chainrings, jockey wheels, but has had a new chain. Again – all weather riding.
Bloody hell, how are you managing that?? I'd be happy with maybe 3000km out of a chain although have never really logged miles on a brand new waxed chain so might get longer. I've just changed my second set of GRX jockey wheels on a bike that has only logged (checks Strava) 4300km, albeit predominantly muddy km.
Edit: actually while checking I compared with my 'good' road bike which almost has 10,000km on the clock and is only on its second chain, so I guess it's not outside the realms of possibility...
Posted : 31/01/2023 8:50 pm
A steel chainring, maybe, but my aluminium ones certainly wore. The steel sprockets certainly don't wear quickly. Mine had over 20000km on it and I bought another for service time, but they were almost indistinguishable from one
another.
Posted : 31/01/2023 8:52 pm
@Daffy I wonder to what degree the drag was the Alfine? Rohloff are meant to be much more efficient
I was also considering an alfine but perhaps I should knock that off my list...
edit: low-power/idle losses for the Alfine are particularly bad, like 25% in some gears!
https://www.cyclingabout.com/speed-difference-testing-gearbox-systems/
Posted : 31/01/2023 10:29 pm
@trail_rat what was the lost time exactly? like mins lost per hour?
Posted : 31/01/2023 10:36 pm
@legometeorology - nice to know my real word test is backed up by lab results.
I experienced about a 10% reduction in speed (26kph average with the Alfine, vs. 29kph on normal gears) and this shows a 10% power loss.
Posted : 01/02/2023 5:46 am
. It's about 5% just under 2mins / 10miles . Or another way about 0.9mph knocked off you speed for a given output.
Not a big number sure but it's measurable and real
Posted : 01/02/2023 7:19 am
Thanks @Daffy and @trail_rat
That's the Alfine off my list. No chance I'd accept 10% losses, nor the spongy roller cluches
The Rohoff... hmm, 5% is perhaps more than I could handle too, but I wonder weather it would be that much for me. My longer rides tend to be quite hilly, so I spend a lot of time in my upper gears, which feel pretty inefficient already
So last question(s) @trail_rat, if you don't mind: what sort of trails were you loosing 5% on: mtb? Hilly? Are you a
high torque or high candance rider? And was the hub worn in?
Thanks 🙂
Posted : 01/02/2023 8:54 am
So last question(s) @trail_rat, if you don’t mind: what sort of trails were you loosing 5% on: mtb? Hilly? Are you a
for purposes of control - it was done on sheltered road.
hub should be worn in it was used for commuting 2004-2009 C~ 8000miles
typically a high cadence rider unless im on my singlespeed.
Posted : 01/02/2023 10:11 am
