Home Forums Chat Forum Old Atco mower project.
  • This topic has 85 replies, 27 voices, and was last updated 6 years ago by fadda.
Viewing 40 posts - 1 through 40 (of 86 total)
  • Old Atco mower project.
  • stevied
    Just picked up a 1960’s B23 Atco as a little restoration project.
    It’s a good runner and cuts very well but is in need of some TLC.
    fadda
    9 minutes, and you haven’t posted the ‘before’ pics?
    Shame on you…
    stevied
    I’ve tried but the stupid f***ing mobile version is impossible to use..😨
    slackalice
    Quick! Before I start using google please! 😉
    fadda
    Is mower envy even a thing?
    I don’t even like cutting the grass, but I fancy a project like that one…
    hot_fiat
    Nice! I took on a 1930s atco. It was an absolute bastard thing with a Villiers 2 stroke. The cretinous heap would happily kick back off the handle and start itself in reverse, when it did run properly, you had to run after it as it was setup to do about 7mph.
    stevied
    As I couldn’t post on mobile, here’s a couple of pics:
    As it runs well, the first job will be to strip as much of the casing as I can to sand-blast and re-paint. I’ll then look to strip the engine to clean/paint then replace the controls/cables to get it up to scratch.
    More to follow….slowly probably 😉
    mcmoonter
    Laughing at hot_fiat.  When we first came here our lawns were in a poor state. My dad borrowed a big industrial mower from his work. It had sort of single wheel clutch to help it make a turn at the end of each cut. One wheel would lose drive and the other would whip your ten year old body off the ground to start the next cut. It may have had that clutch on each wheel to turn in either direction.  It also had a moss scarifier which we only tried once. A single pass of the tennis court sized lawn yielded enough moss to fill a skip.
    Keep the pics coming OP
    singlespeedstu
    That takes me right back to my youth.
    My first job was as a lawnmower mechanic.
    Those old cast iron engines sound so nice when you get them ticking over really slow with just the occasional ching from the centrifugal clutch.
    stevied
    It does sound lovely, like what I imagine England used to sound like on a Sunday morning all those years ago 🙂
    So, should I keep it green? Part of me wants to keep it original the other part wants to make it different…
    fadda
    If it were me, I’d definitely keep it as original as possible.
    I am a nostalgic old Hector, though…
    hot_fiat
    We seem to be a nation obsessed with putting everything in formaldehyde, from buildings to bits of useless 70s tat (especially mechanical stuff).
    Cobblers to that! Steampunk it. Fit an arduodino-based injection system and roots blower then take it racing!
    prawny
    Keep it green, you could probably make a few quid on it. My dad had a couple of Atcos (he was a poper lawn nut) and they cost a fortune, but when he got rid of them they fetched a decent amount too.
    mugsys_m8
    Think there’s a good James May Dismantler episode on an old lawnmower on you tube.
    stevied
    Started stripping her down last night 🙂
    Have got the basic covers off, air filter, exhaust etc so starting the shot-blasting process:
    Luckily I have access to a shot-blaster, polishing kit etc at work so that will help with keeping it cheap as I can do most of the work myself 🙂
    stevied
    Pull-start cover cleaned and given a light polish:
    fadda
    This is very promising – please carry on, stevie!
    CountZero
    Needs James May voice-over!
    CountZero
    I’ve got ever-increasing numbers of cowslips appearing on my ‘lawn’, plus a lot of moss, gives me a good excuse not to mow it. It’s basically just two small squares either side of a path, I just use shears to trim the longer bits.
    stevied
    A bit more stripping tonight..
    stevied
    concept2
    Great project…
    there is a guy on the forum below who knows the answer to any mower related question.  I think he may have had a business in the past.. I did something similar and had some help..
    https://www.oldlawnmowerclub.co.uk/
    slackalice
    Why can’t I see any photo’s? All I have is a grey/white no entry symbol. Shame, as I’d love to follow your very cool project OP 😃
    stevied
    Cylinder bead-blasted and 1st coat of paint:
    somafunk
    no pics showing here either?,
    stevied
    weird, I can see them. Trying to use google pics…copying the address, pasting in the box etc..
    Can anyone else see them?
    Rockhopper
    No, i can’t
    stevied
    Let’s try Imgur:
    Start:
    Some bead-blasting:
    Polished pull-start cover:
    More stripping:
    Painted cylinder:
    maxtorque
    I have to say i’m not a fan of excessive resto jobs!  Leave the patina, but make it mechanically A1
    slackalice
    Nice! 😃  Imgur works!
    Thanks
    fadda
    Yay!  Hooray for imgur!
    Loving it, to be honest, I’m impressed and jealous in equal measure….
    stevied
    I’m not going to worry too much about dents and stuff so it will maintain some of it’s battle scars.
    Glad you can see the pics now, will continue to use imgur 🙂
    singlespeedstu
    You need to clean all the paint of the edge of the cylinder blades then grind the bottom blade flat and adjust it so it’ll cut newspaper as you turn the cylinder by hand.👍🏻
    stevied
    We’ve got a cylinder grinding attachment for the cylindrical grinders here at work so will touch up the cylinder then lap the bottom blade 🙂
    Replaced the old blade height adjusters with some new, stainless ones.
    v8ninety
    Ooh! I acquired an old atco mower too. It’s a bit of a shed (patina, yes definitely patina) and not quite as lovely or collectible as yours, but it’s put some good work in, and the kids love it👍🏼
    View post on imgur.com
    slackalice
    I am liking that! 😎
    stevied
    Looks like a beast v8 😎
    grey
    I’ve a old Suffolk Punch to renovate as a project.
    I really should get round to starting it.
    v8ninety
    It is! It has an (optimistic) 12hp on tap! 😱
The topic ‘Old Atco mower project.’ is closed to new replies.
