Home Forums Bike Forum Maxxis WT 2.5 tyre on 25mm internal width rim
Viewing 12 posts - 1 through 12 (of 12 total)
  • Maxxis WT 2.5 tyre on 25mm internal width rim
  • jpacey
    Would this work? I see they are optimised for a 30+ mm rim but fancy a 2.5 shorter ffor winter
    James
    Scamper
    I eventually got an answer off Maxxis to this. Technically would work but the tyre pattern would be deformed so not work/grip as intended, and they could not guarantee the beed would sit correctly on the rim.
    kimbers
    2.5 shorty isnt massive, works very well on my 30mm rims, cant see that youd have that much trouble
    Scamper
    Ignore me. Read the OP wrong 😆 🙄
    kiksy
    My friend mounted my DHF WT 2.5 to 23mm internal rims and it was fine.
    As Kimbers said, they aren’t massive, roughly the same width as a 2.35 Magic Mary.
    ehrob
    I run them on 29mm internal rims, they’re flipping brilliant. Go for it.
    Just not on the back, I’d expect that’d be quite tiring.
    chiefgrooveguru
    They work great on a Flow EX, really great. That’s 25.5mm internal width, with both the Shorty 2.5 and DHF 2.5
    poah
    no issues on the rear using spank oozy 295 rims (24.5 ID)
    mikewsmith
    Minion 2.5 wt on a 25mm wtb nice size and aggressive for me
    beano68
    I run these on the front of my hope tech hoops (25mm) no bother at all
    Northwind
    I have mine on a 28mm internal 29er rim, no problems at all, 25mm isn’t so different. (same with DHR2 WT) I think it’s mostly hype tbh, in the same way as schwalbe are pretending 2.6 is a plus tyre.
    It’s awesome btw, like cheating in mixed conditions. I really like the 2.3 but throw in a load of roots and wet cold rocks and the 2.5 really takes over.
    jpacey
    Excellent, cheers
The topic ‘Maxxis WT 2.5 tyre on 25mm internal width rim’ is closed to new replies.
