Back from a ride yesterday whilst cleaning the bike I noticed that the rear end had a fair amount of play.
The lower pivot was quickly outed as the culprit and was tightened back up. The bolt was definitely on the loose/about to fall out end of the spectrum.
I tightened it up and left it.
Yesterday evening a quick STW google a couple of posts alluded to stiff/seized bearings could be at fault.
So I whipped out the bolts and spacers and whilst a little grubby the bearings seemed fine.
I cleaned everything down, re greased and packed in some quality water repellent grease. I then thread locked the bolt.
Now was this just bad luck?
I plan on running the bike at my solo bike for MM but am now paranoid that its going to come loose again.
Just bad luck and time to get on with things or sit in the corner, rock and worry?
