the radiation (whether you believe it’s dangerous or not) comes from your phone. the further from the mast you are, the more radiation is emitted by a phone. the closer you are, the less radiation there is.
Err, no.
As said before mobile phones are 2 way, so the Base station transmit and your phone transmit. However, the duty cycle of the base station will be much higher (100% when busy), whereas your phone only transmits periodically when you’re not making a call, so the duty cycle is tiny eg 0.01%. A mobile phone base station also transmit more power than a handset eg 40W vs maybe 2W for a handset.
Now some maths…
Let’s assume you’re 1m away from your handset, FSL for 1m @ 900 MHz = 31.5 dB
Let’s assume you’re 100m away from a base station, FSL for 100m @ 900 MHz = 71.5 dB
So, on the face of it the power from the Base Station is 40 dB less (10,000x). However, the duty cycle of a busy mast is at least 10,000x greater than that of a dormant handset, so the power over time will be the same.
A typical GSM BS is 40 Watts vs 2 Watts for a handset, so the BS is kicking out 20x the power of a handset.
So, in the case of 1m mobile vs 100m GSM mast, you’ll get more EM radiation from the mast when it’s busy by at least 20x, probably more.
NB As for your handset reducing power when it’s near the mast, this assumes that the mast near you is your provider, which is about a 1 in 4 chance.
