Could you work something out with the existing light mount? Drill to take the bolts from the District mount, then place half a seat tube piece and part of a shim between the mount and the clamp?
I have drilled the holes to take the clamp…forgetting that it’s the plastic mount that activates the spring mechanism that holds the light in place! I did wonder about cutting the plastic mount but I’m not sure how I’d keep it in place and have the confidence that it would stay in place during use.
Thanks, I’ll have a look at those and see if they’re suitable.
The ctc forum has a solution
I don;t think that option is really suitable for the MTX due to the way the bag is designed to slide on & off the rack.
TBH, I was hoping for something a bit less Heath Robinson than a bodged option (I know some of you love a bodge!). I’m a bit disapointed that no one on STW has bothered to have a bespoke CNC mount made…
