I’m kind of going on the advice of Tadge at Flotec – he’s worked with the Fox team, I understand.
Regarding what do /don’t I like about the FIT 4 – I’d like better performance over stutter bumps if possible, cut down the arm pump and fatigue. He reckons the FIT 4 oil path is pretty convoluted and it doesn’t flow as quickly, and you get a better transition between low speed and high speed compression with the GRIP.
He did also say that, comparing GRIP with the new GRIP 2, the difference is just more adjustability, whereas the original GRIP just seems to work right without too much faffing and fiddling. I like the sound of this too.
I can get the tech talk, it makes sense to me. Also, sometimes something simpler and well thought out can be better at least in some respects than something more complex (and therefore more expensive). It’s real life comparisons I’m short of!
