Home Forums Bike Forum Gash is Conti 5000 sidewall – repair or leave alone?
Viewing 16 posts - 1 through 16 (of 16 total)
  • Gash is Conti 5000 sidewall – repair or leave alone?
  • yohandsome
    Looks like it’s on the border of needing fixing, but there’s no tube coming out either. Caused a tiny puncture (if I had been running tubeless I probably would have flatted too?).
    Leave alone or repair somehow?
    If you’re running these, definitely avoid rocks and gravel, they cut easily (got a smaller one in the front)
    simondbarnes
    Road race tyre in not great offroad shocker
    I’d bung some superglue in there
    simondbarnes
    Mine seem fine after today’s offroad jaunt (although they are 28mm TL)
    View post on imgur.com
    freddiest
    I’ve had similar with a pair of gp4000s2. I know it’s a race tyre but I can’t believe they are so highly regarded for such a fragile tyre. I’ll be trying another brand next time. Puncture repair patch on the inside and superglue in the gap?
    cynic-al
    I’d keep riding that and keeping an eye on it.
    Super glue has yet to work for me, maybe a patch
    Mister-P
    That’s not the sidewall.
    martymac
    Id be wanting that repaired tbh.
    High speed blowouts are usually pretty crap.
    simondbarnes
    Good point 🙂
    yohandsome
    True. So superglue in the crack plus a patch on the inside, ordered a £2.5 Park tool TB-2 Emergency Tire Boot for the inside, will cut it to size.
    @simondbarnes
    avoid rocks at all cost :S
    Matt24k
    I had what looks like exactly the same damage on my GP5000TL. I super glued the outside and patched the inside.
    FunkyDunc
    How does superglue work? It’s solid not at all supple so surly cracks with any movement ie using the tyre
    boblo
    If you do glue it/mend it/continue to ride it, make sure it’s on the back. A front blowout at speed might be more expensive than a new tyre…
    yohandsome
    Some people report superglue hardening and puncturing the tire, so either way you probably want an interior patch.
    footflaps
    Use shoe glue / seam sealant, takes 24 hrs to set but stays flexible.
    I always carry half of one with my spare tube, just in case I have to limp home with a sidewall tear
    yohandsome
    Yeah seems like a nice product, don’t think regular patches are that good for sidewall tears as they’re too elastic.
    simondbarnes
    When I’ve used it in the past it just seems to help stop other shit getting in there and causing another puncture
The topic ‘Gash is Conti 5000 sidewall – repair or leave alone?’ is closed to new replies.
