Home Forums Chat Forum Garage skirting
Viewing 15 posts - 1 through 15 (of 15 total)
  • Garage skirting
  • nwmlarge
    I would like to fit skirting in my garage, however the lowest courses of brickwork are quite rough and uneven.
    Do they do hollow type skirting or one which clips on to fixings?
    Traditional skirting wouldn’t work.
    kayak23
    You can get box-in skirting that might do what you want.
    Otherwise, could you run a batten on the wall at skirting height and one on the floor and box in the uneven bricks?
    Sorta like this but nicer obvs.
    esselgruntfuttock
    Be careful where any dampcourse comes up to. I just took some skirting off my garage wall, which has been there since we moved here, because I was a bit suspicious of a plant that was growing from behind the board! Turned out the dampcourse isn’t fitted below where the board came up to & it was very damp behind it. It’s drying out now.
    nwmlarge
    The Garage has been in place for 16 years now, the damp course is intact and the garage is always dry.
    The batten idea isn’t a bad idea!
    wwaswas
    It maybe above floor level though and you dont’ want to bridge it.
    nwmlarge
    I don’t really understand what you mean tbh
    Nobeerinthefridge
    Why do you want skirting in your garage?
    bsims
    You could add coving as well to compliment your new skirting. It will add that wow factor when your come to sell.
    Nobeerinthefridge
    senorj
    Good idea. But if you’re going for coving you may as well get some mood lighting and a few scatter cushions too.
    Nobeerinthefridge
    And a feature wall.
    jimdubleyou
    Maybe a mock fireplace?
    kerley
    Don’t forget the ceiling rose
    hamishthecat
    Dado FTW.
    Hang tools from it on those picture hangers.
    finishthat
    Dado – no French cleats instead
The topic ‘Garage skirting’ is closed to new replies.
