Home › Forums › Bike Forum › Fork travel on hardtails – how much is too much?
- This topic has 83 replies, 36 voices, and was last updated 8 years ago by trickydisco.
BadlyWiredDogFull Member
Maybe, just maybe, as just very occasionally happens on STW and elsewhere, there isn’t a black and white, right or wrong answer? Just possibly. Like maybe a frame designed to work with a longer travel fork will work better with one than one designed for a shorter travel front end?
And maybe there are pros and cons to both options? And maybe it also depends on the rider, the set-up of the fork, the terrain, riding style and numerous other variables?
Just a thought.
Love the idea that having a motorsport engineering background makes someone an expert on mountain bike frame geometry btw. How does that work? 😉
maxtorqueFull MemberI can’t see any significant difference between HT and FS when it comes to “slackening geo due to fork travel”.
In fact, if the front fork is compressing, then it must be taking a larger proportion of your combined mass (due to braking hard, or descending steep terrain), which means (as you haven’t actually got any lighter….) the rear must be taking less, which on a FS bike, means the rear suspension is unloading, and hence getting longer, which steepens the head angle even more……………
poahFree Member150mm on my Dartmoor hornet although I’ve got no idea if this is too much as I’ve not actually got to ride it in anger yet ha ha ha ha
jamesoFull MemberLove the idea that having a motorsport engineering background makes someone an expert on mountain bike frame geometry btw. How does that work?
I read it as ‘technically minded with engineering experience and a good rider = probably capable of thinking through the question and having a sound opinion rather than saying what his mate said or writing it off before trying it’ : )
I like what BTR are saying and agree with it, the bike looks like a riot. 120-plenty. I’ve also have had a lot of fun on a 140mm HT. Had pros and cons, like most bikes.
chiefgrooveguruFull MemberAnalysis fail maxtorque! 😉 It’s the dynamic loading that is the issue, not static loading, so the vertical force you’re applying to the bike is often greater than your weight.
When you get on a hardtail the geometry always steepens. When you get on a well set up full-sus the geometry usually slackens, especially on bikes that are ridden harder as forks get run with much less sag than shocks.
kudos100Free MemberI can’t see any significant difference between HT and FS when it comes to “slackening geo due to fork travel”.
Haven’t ridden many hardtails eh?
nickcFull Memberdue to braking hard, or descending steep terrain
ummmm, I leave my front brake well alone when I’m descending, and control my speed almost entirely with the rear brake, I use the front only ever if I need to STOP NOW! (if you see what I mean). I imagine I’ve developed this technique over the years subconsciously to stop the sort of dramatic angles changes that folk on here talk about. The advantages are steering, grip, fork remains active, and so on. Downsides…well, the obvious..
chakapingFull MemberI know it’s a cliché but geometry really is more important than the amount of suspension travel.
Yeah you can have both of course, but experience tells me I’m unlikely to use more than 130mm on a HT anyway.
Those of you riding 160mm forks on a HT, do you manage to get full travel? I can’t see how you’d do it without smashing the rear wheel or getting bucked, unless the fork was super soft.
wlFree MemberRode and Orange SubZero for years with 160mm up front and it was mint. Guided in the Alps on it too. Agree that every so often that much travel can feel a weird on a hardtail but I just got used to the quirks and enjoyed riding all the same stuff as on my full-sus, albeit sometimes slower and with less comfort and control. Depends what the frame is designed around really, and how well controlled your fork set-up is.
chiefgrooveguruFull MemberThere is definitely much more of a thing where the bike rotates underneath you with a hardtail compared to a full-sus. I don’t think it’s all because of the forks either – ride a rigid bike across rough terrain and as the back wheels kicks up on bumps your feet get lifted and you can’t always managed to absorb it all with the legs and keep the hips steady, so that then pitches your torso up and forwards which transfers weight onto the bars.
It’s very rare for my Soul’s fork to go into the last 20mm of its 140mm of travel. I did ride it for quite a few months with 100mm forks but much prefer it with the slacker head angle at 140, despite the higher BB. However, when I’m on my Spitfire the BB height is way lower and the head angle way slacker (about 65 deg vs 68 deg with both at sag), which makes it hard for me to quickly swap between the bikes.
nickcFull MemberThose of you riding 160mm forks on a HT, do you manage to get full travel? I can’t see how you’d do it without smashing the rear wheel or getting bucked, unless the fork was super soft.
Ok, for me, set up of the fork was hugely important, I used to run mine pretty hard. with a LT hardtail, the thing you do is just control the front, big forks are stiffer, and with the likes of a lyrik with 20mm axles it’s not going to get deflected, so you’re not thinking about what the fork is doing, you can concentrate on the the terrain, leave the front brake alone, let the fork do it’s thing, control the speed with the rear (and largely if you stood up, the rear doesn’t take that much of a battering), jobs a good ‘un.
It’s no where near as fast as a FS, but you can’t just sit there, and let it happen like you can on a FS, you have to manage it.
xiphonFree MemberAll I know is, my Dialled Prince Albert (mk1) was fantastic fun racing down Fort Bill with 120mm Fox 36s.
Apart from run 9, in which I pitched forward over the bars and ended up breaking my arm.
brFree MemberJust thinking, but the 456 Summer Season was designed as a slack 100mm ‘hardcore’ HT – I guess the BTR is aiming for the same market.
davidtaylforthFree MemberThose of you riding 160mm forks on a HT, do you manage to get full travel? I can’t see how you’d do it without smashing the rear wheel or getting bucked, unless the fork was super soft.
I’m pretty sure I was getting full travel on my 66’s; but yeh, the back wheel was fairly hammered. Dinged to hell and needed tweaking a few times. Although it was a Mavic 721 which were quite prone to dings. Didn’t puncture though! Although I ran dual ply tyres (a must).
maxtorqueFull Memberchiefgrooveguru – Member
Analysis fail maxtorque! It’s the dynamic loading that is the issue, not static loading, so the vertical force you’re applying to the bike is often greater than your weight.Indeed, but unless the combined CofG height of you and your bike is BELOW the virtual suspension centre, which i’m pretty sure has never yet happened, then more loading the front (dynamic OR static) must result in less loading on the back, and hence a rise in the BB of a full susser and a steeper head angle.
In effect, a HT rotates around the centre (axle) of the rear wheel, whereas a FS rotates around some virtual centre than depends on the geometry, and is generally towards the middle of the frame, at around crank height or a bit higher.
chiefgrooveguruFull MemberNo. When you hammer a hardtail around a berm with your feet heavy and hands light the increased load on the bike steepens the head angle but changes the bottom bracket height only a small amount. This makes the bike more nervous as you go around the berm. If when going around that berm the front wheel hits any bumps then this exacerbates the problem. Likewise if the unsuspended rear wheel hits a bump, the bike and rider will rock forwards, making it more nervous.
Consider a full-sis doing the same: The weight distribution of a heavy feet light hands rider will cause the fork and shock to both compress but the latter by more, so the angles get slacker, wheelbase longer, bottom bracket much lower and the bike more stable. If the front wheel hits a bump then that will have a very similar effect to with a hardtail but from a much more stable starting point. If the rear wheel hits a bump then the suspension will deal with it and the handling change by a negligible amount.
When you get up on the bars, motocross style, you will make a full-sus feel more nervous which is why bikes that benefit from or encourage that riding style are much slacker. But riding a full-sus like that will not feel as nervous as a hardtail with very similar static geometry, and the longer the fork travel, the more the hardtail will diverge from its centred handling behaviour.
maxtorqueFull MemberYES.
lol
I think we are actually saying the same thing, that it is the difference in the location of the virtual centre that you feel when riding a hardtail vs a FS, and not specifically anything to do with the head angle changing.
And of course, all you need to do to unload the BB on a HT (whilst berming) is move your weight backwards, so more load is carried by the rear wheel and less by the front (and yes, that can cause issues, with traction or balance, especially on rough terrain, which is of course why a FS is a quicker bike on said rough terrain (because it can use it’s front and rear tyres more evenly)
chiefgrooveguruFull MemberI don’t think you’re understanding what I’m saying. You can’t shift your weight any further back than the bottom bracket without starting to actually unweight (ie initiate lifting) the front wheel – which is clearly a bad idea when you want the tyre to grip! And if you load the rear more heavily then it’ll buck more and destabilise worse through the rough.
maxtorqueFull Membermaxtorque
all you need to do to unload the BB on a HT is move your weight backwards, so more load is carried by the rear wheel and less by the fronter, isn’t that EXACTLY what i just said?? 😉
davidtaylforthFree MemberHopefully a Semenuk table on a short travel hardtail will get this thread back on track…..
benpinnickFull MemberI think this thread is a perfect example of a debate without an answer. There’s no right or wrong, as when you actually look at the real numbers, its much ado about nothing.
Assuming you have either a 120 fork at 75% sagged, or a 150mm fork at 70% sagged (a perfectly reasonable assumption that with the extra travel you’re longer fork allows you’ll run it softer with extra progression or HSC to keep things in check a little), then your head angle deviation from sagged for the remainder of the travel looks like this:
less than 1 deg difference at full compression.
Factor into that:
This HA variation doesn’t happen in normal trail riding where the fork impacts bring the axle to you.
This HA variation is only caused by g-outs and front end impacts, representing a much smaller amount of fork activity, probably less than 5% of all the work your fork does.
This HA variation is often as likely to occur on an FS as it is a hard tail.Suddenly you’re looking at <1deg moderately infrequently, its not seeming nearly the issue you might have thought it was, and most of the time its happening its nothing to do with this graph but the rear wheel movements, which are occurring irrespective of fork length. Control and setup is everything, the actual variations between HA isn’t all that much <1deg is not enough to change something from great to terrible. Not even close.
davidtaylforthFree MemberIt’s gonna take more than that I fear.
Ok; to add balance. Here’s someone about to go over the bars on a long travel hardtail
poahFree Memberwould be OTT on a FS as well. poor technique and low fork pressure would put you OTT not that fact that its a hard tail.
davidtaylforthFree Memberwould be OTT on a FS as well. poor technique and low fork pressure would put you OTT not that fact that its a hard tail.
I agree. I was just contrasting a badass table top pic, with a mincing over the bars pic, to highlight just how uncool long travel hard tails are…
benpinnickFull Memberwould be OTT on a FS as well. poor technique and low fork pressure would put you OTT not that fact that its a hard tail.
Probably more likely on an FS.
davidtaylforthFree MemberI don’t think 120mm is particularly “short” travel. I’d say somewhere around the 100mm mark would be closer.
It’s not just geometry changes that make the long travel forks poor; it’s the fact you’ve got to wade through 150mm of travel, and then back again, to be able to do anything with the front end/bike in general.
thegreatapeFree MemberBen, how did you decide on the travel you designed the Zero for? Was the bike designed round the travel you wanted, or was something else the starting point and the travel chosen was what was required to make it work? What’s the process for deciding all these things?
deanfbmFree MemberI really don’t like the feeling of any travel on a HT MTB, can’t be dealing with that constant change in geometry, end up running it real hard, they don’t end up doing anything anyway.
FS or rigid for me.
davidtaylforthFree Memberjust for balance, not going OTB on a LT hard tail…
I dunno; they might be. It’s hard to tell from the pic 😀
BigDummyFree MemberI currently have 140mm on my 650b hardtail. I don’t think I generally get full travel, it’s set fairly hard and the geometry change thing isn’t a noticeably huge deal.
The previous bike was a 29er, with 120mm. Same applied.
I’d be very interested to try the BTR if it wasn’t a zillion pounds, and hideous, and I didn’t have a rad hardtail.
benpinnickFull MemberBen, how did you decide on the travel you designed the Zero for? Was the bike designed round the travel you wanted, or was something else the starting point and the travel chosen was what was required to make it work? What’s the process for deciding all these things?
Mainly built around the forks. When you look at 100 vs. 120 vs 130 – things like increased HA change are actually pretty marginal – we’re talking under 1.5 degrees for identical setups, and less than 1 degree if you engage your brain and set your forks up properly. The kind of numbers that on paper look like a real difference, but if I lied to you and said something was + or – 1 degree 9 times out of 10 you’d not notice. What makes a big difference is control. Normally that would mean shorter is better, but on the Zero we wanted to offer the best blend of control and travel we could – At the time, that meant running a 140 Pike as it was delivering the best control of any fork out there with the chassis stiffness to boot. Designing for anything shorter was a compromise on everything else, all the time. We dropped the lower priced forks to 130 to compensate a little for their lack of adjustability and control however, and designed the Zero around 130/140 forks.
With the TR and AM, we had the chance to expand the testing a little. We have Sids, Rebas, pike 130/140/150/160s, Yaris, Lyriks, Streats, Velvets and Sweep HLRs to play with in the test fleet. However, when it came down to it, having tested lots of different combos, we settled on the 130 Pike first for the TR. Thats the fork we’d have probably built the original Zero around if it were available back then. Once we’d decided on the 130 for the TR, its just a question of what to make the AM. We knew we’d want it longer travel – not because that would be ‘better’, the TR is the better all round bike of the two for sure, but because we wanted to make a bike that replaced the very popular AM build kit of the Zero Mk.1 and the jump from 130 > 150 was too great to make 1 frame alone.
On the AM, we found a budget fork that actually works at 150mm – the Sweep HLR, and then of course Pikes. We wont be offering any other fork options on that model as it just doesn’t work well without that level of control. Well, we may add the Yari, but I find the Yari air spring harder to get set up just right than the Pike, so we’ll see about that.
The TR will run the 120 forks too, so whether we will offer a 120 forked version now they have become available? Maybe. Depends on volumes at the time and whether its justifiable for us to buy them in too I guess.
thegreatapeFree MemberThere was me thinking it goes something like ‘we want this much travel and this head angle, so if the forks this long here’s the sums for the rest of it’ 🙂
asdfhjklFree Memberdeanfbm – Member
I really don’t like the feeling of any travel on a HT MTB, can’t be dealing with that constant change in geometryFS geometry changes as it goes through its travel too, even more so because it’s happening at both ends.
chakapingFull MemberI’d be very interested to try the BTR if it wasn’t a zillion pounds, and hideous, and I didn’t have a rad hardtail.
Come on man, you’ve used this forum enough to realise that theory ALWAYS trumps experience.
jamesoFull MemberBen’s point about the actual geometry difference being small, and it’ll certainly be minimal when the fork is working, backs up how I think so much of bike set up is about feel and we can be pretty sensitive to that. If 2 bikes have comparible general geometry what I notice about longer forks is the added movement, as DT says, picking the front up out of more travel, that sort of thing (accepting that a longer fork with better damping may feel better there). Some of it will be set up but having ridden very similar frames with forks I’ve adjusted to suit the 120 to 140/150 step felt quite different, I can see how some will prefer one over the other. The numbers are small but the difference in feel can be more significant.
During testing for the new Iroko with 120 and 130mm forks there were comments saying one felt a bit longer travel. It was noted pretty quickly. It could be a sense of ‘this feels a bit softer/longer and I prefer shorter’ initiating the comments rather than any real pro/cons, but of interest all the same.
The topic ‘Fork travel on hardtails – how much is too much?’ is closed to new replies.
