I’ve got a Merlin G2X gravel bike and been very happy with it. Some time ago I was aware of some cracks that appears on the front forks in two places, where the front caliper bolts into the fork and a circular areas where axle terminates. They don’t appear to have gotten any worse from what I can tell. I spoke to Merlin and they just say take it into a LBS to get an opinion whether its something more serious or not. Appreciate pictures aren’t the same as physcially looking at this – but has anyone seen this sort of thing before. The forks are carbon so presume the areas with cracks are where alloy is bonded with carbon (?).
Honestly, they look like paint cracks from the pictures, but you’d have to ask why the paint’s cracking. I think Merlin are right to ask you to take it to a bike shop to get it looked at.
I wouldn’t ride that and I lean towards ‘it’ll be reet’ end of things.
That fork wants replacing, whether merlin feel it’s on them or you to foot the bill could be a protracted conversation about overtightening bolts /who did that/whether it’s a cyclic stresss fault but i don’t think in this case you need anything more than pics to decide that one way or another it needs to be replaced.
You may have used bolts that are too long on the disk mount, have seen this before where the bolt hits the carbon inside the fork beyond the threaded insert.
It looks like the Aluminium (I assume) inserts, one around the axle entrance and another where the caliper attaches to the fork, are breaking free of the carbon-fibre.
Reading the OP, I was disappointed with Merlin’s response in that seems a cop out to get an lbs to stick it’s neck out and make an assessment; based on the pics, can’t see why it isn’t up for Merlin to request they be returned for assessment or at least suggest some additional tests first
For whatever reason, (and there may be many), the cracks are at the alloy/carbon bonds, so any more failure may result in more movement/ more separation and you having a very bad day.
It might just be filler that’s cracking, but two things:
Why?
and
What are the consequences?
There might be an immediate danger from the “Why?”
If no immediate danger then I’d be concerned that a bit of salty water in there from winter gritting and you’ll get a corrosion cycle going as a longer term consequence
Either way I’d be going back to Merlin and not the LBS
I generally err on the side of “it’ll be fine” (I rode a SX Trail with a cracked chainstay for a few years) but I wouldn’t even ride those forks to the bike shop to get them looked at.
Will Merlin warranty them if a bike shop says they’re unfit to ride?
I know very little about carbon fatigue but that looks to have moved enough to cause the paint to chip off rather than just crack. As it’s the front brake/front wheel area I’d not be comfortable riding it until it was checked over.
A fork failure is a huge deal. I survived. I don’t know what happened. I lost about 40 minutes. I just remember along walking with a bike on my shoulder and noticing that the forks and front wheel were flapping about only held on by the cables. My helmet had a dent at the front and the ends of both bar ends were covered in dirt.
Buck passing. A shop should send it back to Merlin for their opinion since the shop can’t know how the fork’s made and to be fair how many composites experts work at bike shops? (how many at bike brands for that matter)
imho for an online diagnosis – I would not ride that.
Looks like the carbon layup has delaminated from the aluminium inserts at the brake mount and spindle, allowing moisture to penetrate the gap with subsequent corrosion and swelling of the aluminium inserts.
IMHO they’re scrap and *I* wouldn’t be riding on them.
It doesn’t look safe, as others have said, and personally I’d would have thought that Merlin would want that replaced ASAP (and perhaps have a look at what’s going on in case there’s a wider problem with those forks).
Thanks for the replies, I took it into a local bike shop and they pretty much concluded what was said on here… plus to be 100% sure that it would need to be x-rayed to identify if there is any structural failure(s). I wouldn’t be surprised if the cost of analysis outwieghs the cost of a fork :-)
I’ll got back to Merlin and see if they are interested in helping out a long term customer….
Merlin in being shit over dodgy fork / warranty.
I’m not surprised.
They were happy to sell a new bike with missing mounts/badly made fork and basically shrugged when I contacted them and then didn’t reply.
I’d have expected Merlin to be as proactive and helpful as possible on this one. Given the legal ramifications facing several bike companies right now over fork failures causing such unpleasantness as broken backs and paralysis. Unless of course no one at Merlin reads the news. In such a situation it would be quite surprising if the law cares what Merlin’s warranty period is, though I’m no expert.
My experience is that they really could not give a flying shit about warranty or poor manufacturing. They sold the bike. They have your money. Done.
They also block/don’t publish reviews unless they are positive.
Oh well, Merlin have bascially said it’s out of warranty and based on the LBS conclusion yes new forks are required, provided a link.
I subsequently kick myself as I found some pictures I took within 12 months of owning this bike which showed these cracks starting to occur so technically the issues was there within the warranty period… but due to other things that were going on in my life I didn’t have the time to deal with it. Hey ho.
At this stage I don’t think i’d be buying another Merlin.
I don’t know hat caused the cracks but if you feel there was no misuse or the wrong bolts used etc you have 6 years to claim under the consumer rights act. The reasonable expected lifespan of a bike fork might be under 6 years according to some brands but it should be more than a year.
I’ve got a pair of ragley trig forks I bought in the wiggle fire sale, which i’m not going to use now. Could give you a good price on them, PM me if interested…
I think it is absolutely worth going back to Merlin quoting the consumer rights act.
Especially since you have some evidence that something was amiss sooner. While the onus may be on you to prove the failure occurred earlier (it may not, I don’t know) you also have that proof.
Given they are now confirmed as goosed, and you aren’t getting a replacement, why not sand the paint off to see how close you were to dying horribly.
I have a set of barely used px forks off a tempest up for sale for 60 quid if you need a replacement. Although I see merlin are selling your exact forks for half price right now should you feel like giving them a second chance
The fork appears to have failed in two places – that may be because an initial fault has caused water ingress / further damage but the alternative would be that an incorrect bonding agent was used or similar. I would imagine it’s very difficult to tell the two apart without destroying the fork for a proper look or an expensive (unrealistic) X-ray examination.
This is excellent news.
I am surprised that Merlin didn’t offer to help you out with this – a fork failure lawsuit is not trivial! I suppose your difficulty would be if you replaced / re-torqued the front brake bolts as they could argue you caused the failure by improper maintenance but I think you have a strong argument that what you bought was not fit for purpose. It’s worth going back to them with the evidence that the cracks appeared much earlier than you realised. And then feeding back on here what their attitude is to such a potentially catastrophic failure… As a bare minimum they can sell you a compatible fork at cost. I’d probably be happy with that.
As pointed out earlier the exact forks in the exact colour is half price on merlin as I type. Which leads me to believe they probably want rid of them due to oversupply
Given they have a customer with a clearly borked fork, which aside from the social media flaming (see giant), could directly result in a fairly substantial law suit directed at them if it failed catastrophically, I find it staggering they don’t just sent one out as a gesture of goodwill given they clearly have excess stock
the cynic in me says if they have the exact same fork they are trying to offload, how do you know it won’t have exactly the same issue (if it is an manufacturing problem)?
[edit] getting rid due to oversupply (surely a seller will order a similar amount to forks as frames for a bike like this?) or trying to shifting defect stock?
