Removing the Stink from Shoes
Shoes can quickly become dirty and smelly. Whether the odor is coming from your feet or the moisture left in your shoes, it’s fairly simple to get under control. When cleaning shoes, your main objective is to kill the bacteria that is growing and causing the foul smell. This can be accomplished in several different ways.
Table of Contents:
Washing your Shoes
Using Bleach
Using Baking Soda or Vinegar
Using Inserts to Remove Odor
Removing Odor From Your Feet
Additional Tips and Ideas
Washing your Shoes
What You Will Need:
Washing machine
Pillow Case
Detergent
Bleach (optional)
The Cleaning Process:
Remove the shoestrings, and soles (if possible) from your shoes.
Place the shoes in the pillow case.
Place the pillow case in the washing machine.
Run the shoes through a normal cycle using HOT water and plenty of detergent. If your shoes are white, you could also add some bleach.
If the odor is very strong, you may want to run them through two complete cycles to get rid of the odor.
Using Bleach
What You Will Need:
Tea Kettle
Water
Bleach
Sink (or this can be done outside)
Begin by filling the kettle with water and bring it to a boil.
Set your shoes in the sink or on a clean surface outside.
Fill each shoe with boiling water and add a small amount of bleach.
Let this set for a few minutes.
When the water has cooled, dump out the water and wash following the instructions above. The bleach will kill the bacteria, thus removing the odor.
What You Will Need:
Baking Soda
Vinegar
Begin by filling each shoe with approximately 1 cup of baking soda. (use less for smaller shoes)
Add 1 cup of vinegar to each shoe. This will cause bubbling and fizzing.
Let this set and work in your shoes for about 15 minutes.
Remove the mixture from the shoes, rinse, and wash following the instructions above.
